So I went ahead and bought the stuff!
Old Feb 21, 2007 | 03:14 PM
plumpzz's Avatar
plumpzz
Default So I went ahead and bought the stuff!
I bought tokicko springs/dampeners for the Z. Im pretty excited as I really needed a drop on my Z. I wanted to know from current members what setting I should start off at. I currently have cusco swaybars front and rear and they're set for neutral steer. (No over or understeer) with my current tires.
Old Feb 21, 2007 | 05:23 PM
ncdoc's Avatar
ncdoc
Nice. I am interested in this setup - nice drop and linear springs. Let us know how much drop you end up with...
This thread looks like a good starting point re: settings...
https://my350z.com/forum/showthread....tokico+springs
I haven't been able to dig much of any info up about people running the Tokico shocks AND springs.
ncdoc
Old Feb 21, 2007 | 08:23 PM
plumpzz's Avatar
plumpzz
Me either. Most people run the dampeners without the springs. I did some seraching and i found that these are the stiffest linear springs u can buy other than the nismo t2 ones. Ill take a picture before and after as well as measure all 4 corners.
Thanks for that link. Im gonna do 3 from full stiff front, 2 from full stiff in the rear. I was gonna lean to a slight bias toward the rear so I can have a little bit over oversteer and loosen up the front sway bar by 1 notch.
Old Feb 22, 2007 | 12:53 PM
MarkM's Avatar
MarkM
I have Hotchkis springs, but I found 2 on the rear too harsh, currently on 3 front and rear.
Old Feb 22, 2007 | 04:16 PM
ncdoc's Avatar
ncdoc
Good info. I was wondering if the camber kit will be necessary with the drop. I have read anywhere from 3/4" to 1+" drop with the springs. Was looking at these: http://z1auto.com/prodmore.asp?model...ng&prodid=1314
How do you like the Cusco sways?? I had the Hotchkis on my 03 (long gone) and liked them. Hard to beat the price anyway.
ncdoc
Old Feb 22, 2007 | 08:35 PM
plumpzz's Avatar
plumpzz
I dont knwo if a camber kit is neccary but I will be getting one to tune out the suspension some more.
I love the cusco sway bars. I know they're the most expensive set out (465 for f/r) but they're very solid pieces and are very very stiff.
Old Mar 2, 2007 | 09:29 PM
plumpzz's Avatar
plumpzz
HOE MAN this setup ROCKS! Several things I've noticed:
No more jittering. The whole car doesn't get upset when I hit a bump. Greatly imporved ride. Its not softer, but its less like driving on 'tippy toes'
No more nasty wheel hop, AT ALL. I did a burn out on dry pavement and it didnt jump a SINGLE bit. The car slid out under me and caaught traction. No more wheel hop on shifting.
Improved handling, duh. The springs are perfectly matched. The car doesnt want to lift up the innter tire on a sharp turn if i hit a bump. It would before because my sways are stiff.
The drop isn't 1''. Its 1'' in the front, and more like 1.5'' in the rear. I can fit 1 finger in the rear gap now that its settled, im running a 275/40/18 in the rear. After getting the fenders cut, i can probably fit a 295/35 snuggly.
Im running at 3/3 from full stiff front and rear, on cusco sways full stiff on ****TY kuhmo ASX tires. They're now the weakest part of my car.
My camber is wayyy off. The rear is so noticible. Im guessing around -2.5 in the rear. The front isnt changed much. Probably still around -2.
Old Mar 3, 2007 | 11:17 AM
ncdoc's Avatar
ncdoc
Thanks for the reply!!! Sounds nice. I am not sure if I want that much of a drop but I bet it looks nice. Congrats!
ncdoc
Old Mar 3, 2007 | 01:29 PM
chris'smax's Avatar
chris'smax
Thats good to hear! This is the same setup i am going with. How comftorable is the ride with the struts? Did the sway bars make the a difference in how ruff the car rides?
+++1 on the Kumho ASX tires. I just ordered a pair of 275/40/18 Sumitomo(sp?)HR2's for the rear. They are supposed to be a great bang for the buck tire. I have already put my car in a ditch and fish tailed multiple times because these tires can not grip for ****.
Old Mar 3, 2007 | 08:09 PM
plumpzz's Avatar
plumpzz
I have it set to 3/3 and its very comfy. Its softer than stock but the rebound is MUCH improved. The car doesnt get all upset if I hit a bump during a turn. It feels like a whole different car. Think..M3.
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
