Dropped on coilovers, worthin getting alignment yet?
Old Mar 3, 2007 | 08:41 AM
nkohler's Avatar
nkohler
Default Dropped on coilovers, worthin getting alignment yet?
All,
I recently installed Cusco Zero-2 coilovers. EVENTUALLY (as in in the next 6 months) I plan on doing it right and putting adjustible upper a-arms and rear camber arms on the car.
My question: Is it worth getting an alignment done now? The car is not a daily driver and is only taken out to autocross, and on nice days. I know the camber is really negative because I can see it just by looking at it, but I am most worried about toe. Would replacing coilovers effect my toe in any way? Camber does eat up tires a bit faster, but toe-in will just shred tires. Would you get an alignment done now just to be sure? Prior to the coilover install my toe-in was correct.
thanks
Neil
Old Mar 3, 2007 | 09:49 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
without front and rear adjustable pieces, you are limited to adjusting toe only - I'd probably get it checked but I'd focus on getting the rest of the pieces so you can do a proper alignment, or you'll risk killing your tires in no time
Old Mar 3, 2007 | 11:03 PM
anotheraznguy's Avatar
anotheraznguy
your toe may be off substantially depending on how low it went..
anytime i mess w/ suspension i always do an alignment
better to spend 100 dollars in prevention than 1000 dollars in tires
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
