Need some help with spring install
Old Mar 4, 2007 | 05:16 PM
zracin's Avatar
zracin
Default Need some help with spring install
Ive asked and called around, but cannot seem to find a place to put springs on for less than 350 dollars! this seems rediculous to me. Is there anyone around Atlanta that would be willing to help me put a set on, or someone have a spring compressor lying around I could borrow. even a recommendation for a place that can install them cheap. Thanks in advance.
Old Mar 4, 2007 | 05:51 PM
THE TECH's Avatar
THE TECH
Is this a spring install or spring/shock combo?
Old Mar 4, 2007 | 05:56 PM
Eazzy's Avatar
Eazzy
If they are just springs u dont really need a compressor---I can do a set in 2 hrs or so with a little help and takin my time
Old Mar 5, 2007 | 07:11 AM
zracin's Avatar
zracin
it is just springs- no shocks
Old Mar 5, 2007 | 03:55 PM
JoeyFyed's Avatar
JoeyFyed
you can rent the compressor for free at pep boys or kragen whichever, just leave a deposit
Old Mar 5, 2007 | 04:42 PM
Mazinger Z's Avatar
Mazinger Z
I think for the front ones you would probably need a compressor to take off the stock springs. The rear ones should slide in pretty easily. A manual spring compressor you could borrow at Kragens or Pep Boys like another poster said. You should have a good socket set before you start. Namely a 17mm socket and preferably power tools (would make it a lot easier). Good luck.
