Lowering questions, stance coilovers.
Old Mar 6, 2007 | 05:06 PM
Drift_corners's Avatar
Drift_corners
Default Lowering questions, stance coilovers.
I recently purchased stance coilovers for my 06. I want to drop the car. As it sits it seems the front of the car allready is pretty low. I have 30 series tires in the rear. I dont want a big gap, thats my pet peeve. a gap over the wheel. P.S (money is tight)
My question is what should i buy, should i just drop the front an inch. and use the extra camber to my advantage, then lower the rear like 1.6-1.7? and just buy rear camber arms.
What would you all do. Drop, and camber correction wize The z is going for the low stock body look. Rota P45r 9.5 all four corners. 265/35/18 285/30/18
Old Mar 6, 2007 | 07:51 PM
Gsedan35's Avatar
Gsedan35
You'll still get inside tire wear on the front's at a 1" drop, but much less so then if you were running something far softer in spring rates like oem or lowering springs. So I don't see a problem with 1" in the front without correction and a bit more drop in the rear with correction.
Old Mar 6, 2007 | 07:54 PM
Drift_corners
how far do you think i could go with the front.
Old Mar 6, 2007 | 08:26 PM
Gsedan35's Avatar
Gsedan35
Given what your after and how you've said things, 1". But, it's really up to you. You can alway's try something lower and watch your front wear pattern.
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
