SPL Control Arm Owners....
Old Mar 23, 2007 | 06:53 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Originally Posted by accordfreak
but now you have to pay to get another alignment.
Actually you don't have to, just measure the length to the center of the ball joint from a reference point on the arm, if you keep that the same the setting is unchanged:
Old Mar 23, 2007 | 06:58 AM
kuah@splparts.com
Originally Posted by 1cockyZ
Is the street spec ball joint as strong as the race spec. I am considering buying these arms. My only hesitation is noise. I have jic flta2s and had to switch the rear pillowballs for rubber mounts cause is couldn't take the noise. The fronts I get a little knock on bumps. With the spherical bearings 3 per side with these arms are they quiet. I would expect a little noise. I have only heard good things about spl stuff, but I live in nj and the roads are sh*t.
The street spec ball joint is not a strong (rated at 15,000lb vs. 20,000lb) and has less articulation angle, as compared to the race spec ball joint. That is why we continue to offer the larger ball joint for the racers, however the street-spec ball joint is still plenty strong (at 15,000lb rating) for any use.
All responses we had indicate the arms are perfectly quiet in use...
Old Mar 23, 2007 | 07:11 AM
TSW910's Avatar
TSW910
sorry to be all confused lol .. but for the G35C .. does this change as if it was on a 350Z ? like how it sits and reacts to a 350z or G35c? currently i am looking into the cusco, but i've been coming across your company's product and eveyrone seems to love it ..
btw, i plan on putting my G on the track this year .. please recommand .. thanks
Old Mar 23, 2007 | 09:46 AM
kuah@splparts.com
How it sits is the same with the 350Z or G35, but I think more people are having clearance problems on the G35 because it is a heavier car. So for the same spring rate, the G35 will experience more suspension travel...
Old Mar 23, 2007 | 10:15 AM
Kolia's Avatar
Kolia
Originally Posted by WA2GOOD
^^ once again, great visual description Kuah. These are great arms just as everything else I have seen and tried for SPL. You can get them from SPL themselves or one of its dealers, which I am happy to be one of.
Scott@RelentlessAutosports.com
Emailed !
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
