Bilstein PSS9 VS Tein Mono Flex
Old Apr 25, 2007 | 08:35 AM
cy350's Avatar
cy350
Default Bilstein PSS9 VS Tein Mono Flex
Hi! I am new to this forum. Hope can share some experience here.
I am thinking to upgrade my stock to Bilstein PSS9 coilover or Tein mono Flex.
Anyone is using those C/O. Please give me some hints for my shopping.
Old Apr 25, 2007 | 08:36 AM
jimmyloose's Avatar
jimmyloose
Bilstein anyday.
Old Apr 25, 2007 | 08:39 AM
cy350's Avatar
cy350
Thanks for your quick reply. Are you using Bilstein? Any comment about it?
Old Apr 25, 2007 | 10:23 AM
type7's Avatar
type7
PSS9 has better built quality and better quality control.
Some tein are good some are not. My friends EVO's Tein Flex was really good and my Old tein Flex for Civic Si is bad for big time.
It will not cost you much to rebuid pss9 in US.
Old Apr 25, 2007 | 06:46 PM
Gsedan35's Avatar
Gsedan35
Oh wow, you've made two choices that are rather polar opposites, kinda doesn't look like your making choices based on any kind of research as to really know what's good or bad about either choice. So I see a different reason to call for research.
Biltein's PSS9 kit uses spring rates that are mildly stiiffer then oem with progressive springs in the rear that have a wide rate spread between initial and final rates. The kit adjust's rideheight by adjusting spring preload. This setup will appeal most to those that only want a mild increase in roll stiffness and are unconcerned by the dynamic's of the progressive spring setup in the rear and it's effect on at the limit behavior. Without question, Bilstein offer's good products that tend to be valved well (can't be said about all Z33 products on the market), and you have Bilstein shop services at your disposal should you need or desire that.
Bilstein PSS9 coilover (Monotube construction, adjustable dampners)
Special Note: Mild spring rates, but Bilstein says the dampners are performance valved
Spring rates 370/240-420 (rear progressive)
Z33 oem spring rates 2003-2004 314/342 2004.5+ 314/427
In comparison, Tein's Monoflex is at the other end of the market place, with spring rates that are amoung the highest offered for the Z33. One must be able to say you can run that much spring successfully, maintaining tire contact is the key. The setup does have full length adjustable dampners for the ability to adjust ride height independent of spring preload and you can use Tien's EDFC if you desire.
Tein MonoFlex (MFP) (Monotube construction, adjustable dampners)
Special Note: Use's spring rates that may not actually benefit you, decide carefully if you will be able to maintain tire contact where you drive in everyday or on your favorite track/course.
Spring rates in LBS 783/783 (Tein does valve them to use a 112lbs lower spring rate if desired).
These would offer you a choice that is inbetween.
Tein Flex JDM specs
Full-length adjustment and height adjustment for separate setting of the height and spring preload
Spring rates 560/560
Side Note: This is the original specs first offered in the U.S. with the Flex, shortly after it’s introduction the specs changed (672/672 LBS)
Old Apr 25, 2007 | 06:54 PM
Gsedan35's Avatar
Gsedan35
http://www.bilstein.com/services.php...9b7b60afae3387
http://www.tein.com/overhaul.html
Old Apr 26, 2007 | 08:29 AM
cy350's Avatar
cy350
Thanks for all your reply. I pick PSS9 today because heard many positive commend on my friends cars and I also concern the daily ride comfort. Will install it this weekend adn hope I make the right choice.
Old Apr 28, 2007 | 08:34 AM
cy350's Avatar
cy350
Installed the PSS9 today. First impression compare with stock, more comfort, quiet, better in corner, easier to control. Will do more on the setting next week. I think I got a right choice. At least fit my driving style and daily drive.
Old May 3, 2007 | 06:47 AM
streetracer's Avatar
streetracer
Bilstein is german. Like all german cars, suspension is undersprung and overdamped.
Tein is japanese, and the japs like their cars to be oversprung. If you have good roads were you live, thats ok. If not, I would prefer overdamped for better highspeed stability and bad roads.
Does that make sense?
Bodyboarder81
Nov 2, 2015 12:17 AM
nanotech
Oct 2, 2015 05:02 AM
