Thanks to Ptuning. Rear Camber Kit install and 4 wheel Alignment.
Old May 7, 2007 | 10:02 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Default Thanks to Ptuning. Rear Camber Kit install and 4 wheel Alignment.
I lowered my Z on Tanabe GF210s and my Camber/Toe/Alignment was way out of spec. Thanks to PTuning my Rear camber and toe is back to stock spec. My front toe is back to spec. The front camber is acceptable (Requires a pricey front camber kit to adjust camber). Here's a few pics.
Before pics of the camber being way out of wack.
Initial Rear Alignment
Initial Front Alignment.
During install and after the alignment.
Rear camber and toe are back to stock spec.
Final front toe was actually .04 for each (he was still adjusting the toe)
Old May 7, 2007 | 10:05 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
nice! this is probly a newb question but I take it you don't need to take the wheels off for the alignment? Also how low is the tanabe dropping you?
Old May 7, 2007 | 10:15 AM
dutchboy350Z
Finally some go
Nope, wheels need to stay on for a proper 4 wheel alignment. I'm dropped about 1" in the front and 1.2" in the back.
I highly recommend a rear camber/toe kit if you're anywhere near a 1 inch drop. Riding on stock camber arms and toe bolts will cause excessive tire wear. Last time I check a set of rear tires cost a lot more than a camber/toe kit.
Old May 7, 2007 | 10:22 AM
tHisZ_bFAST's Avatar
tHisZ_bFAST
PTUNING service is top notch! You should check out their crazy sound-proof dyno room.
Old May 7, 2007 | 10:38 AM
kbomb's Avatar
kbomb
may i ask how much did it the total cost come out to for springs, camber kit, alignment, etc...?
Old May 7, 2007 | 11:16 AM
tkrienke's Avatar
tkrienke
Looks good. Side note: the alignment computer says 18" wheels??
Old May 7, 2007 | 11:21 AM
dutchboy350Z
Finally some go
PTuning is running a special right now. SPC Rear Camber/Toe Kit, Rear Camber/Toe install, and 4 wheel alignment for $475 (Tax included). As far as I know, this is the highest quality alignment machine on the market. The install took about 2 1/2 hours start-to-finish. https://my350z.com/forum/mid-atlantic/264174-ptuning-350z-g35-4-wheel-alignment-w-spc-rear-camber-kit-special.html
To put things into perspective I just bought new rear tires from discount tire direct for $460 (mounting and balancing not included).
Old May 7, 2007 | 11:24 AM
dutchboy350Z
Finally some go
I may be wrong but the diameter of your wheel has nothing to do with your camber and toe adjustment. The width of your wheel and the lowering of your suspension is what effects camber/toe in the rear. Plus I think that is just the title of the file it was saved to (Notice the spelling of "Road Star").
Old May 8, 2007 | 08:01 PM
dutchboy350Z
Finally some go
Checked it out when I was there ... definitely state of the art
Old May 8, 2007 | 08:07 PM
DBTRACK's Avatar
DBTRACK
how is that machine attached to your wheels??? I need this done, but am afraid of scrathin my Volks.....
Old May 8, 2007 | 09:16 PM
dutchboy350Z
Finally some go
No scratches at all. The alignment laser sensors are attached to you tires, NOt your rims.
Old May 9, 2007 | 12:54 PM
DBTRACK's Avatar
DBTRACK
Great, thats what I thought but just wanted to make sure.
JjL
East Canada
Jun 12, 2019 03:04 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
