rear camber is adjustable
Old Apr 26, 2003 | 04:19 PM
N74DV's Avatar
N74DV
Default rear camber is adjustable
For some reason I was under the impression that both front and rear camber was not adjustable.
I crawled under the Z today and noticed that the rear is adjustable.... it's news to me.
There are cam washers that locate the lower control arm bolts where they attach to the frame of the car.
I wonder how much adjustment they provide?
I'll be installing my Eibach springs this week and was hoping to be able to twaek the rear camber back to stock if possible.
Old Apr 26, 2003 | 05:25 PM
jak's Avatar
jak
There is enough adjustment to bring around 3/4" of drop back into spec. Eibachs lower the rear 1.2" so you will need camber kits if you want the stock spec.
If you don't install camber kits let us know how close you can get to spec without the kits. There are a lot of members here that I think would be interested.
Jeff
Old Apr 27, 2003 | 05:39 AM
Pedal Pusher's Avatar
Pedal Pusher
Default Help for camber problem?
Thanks for the info. We are all waiting for your results.
Old Apr 28, 2003 | 07:27 AM
vance45's Avatar
vance45
I just got my alignment done, after a week with Eibachs. The fronts don't look too good.
Front:
Caster
L = 9.2 R = 8.7
spec = 8.92 to 7.58
Camber
L = -1.3 R = -1.5
spec = .17 to -1.33
Toe
L = 0 R = 0
Rear:
Camber
L = -1.7 R = -1.9
spec = -1.08 to -2.08
Toe
L = .10 R = .05
Old Apr 28, 2003 | 10:33 AM
Pedal Pusher
Default Camber
vance45
Thanks for the info. I feel we need to get close to 1 degree negative camber to show improvement in tire life.
Old Apr 28, 2003 | 11:42 AM
jak's Avatar
jak
I agree. I also think a front camber closer to the -.2 to -.3 range would eliminate some of that inside tire wear (feathering) some people are reporting.
Jeff
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
