Rear camber Kit question
hey all
i just installed the HKS Hipermax RS coilovers in.
shop had to slam the back of the car to get it to be at the oem height for some reason.
but anyways, that made the wheel camber in REAL bad. i look like a really bad civic on cut springs in the back lol.
the front looks fine.
i found these two kits.
https://my350z.com/forum/showthread.php?t=279567
https://my350z.com/forum/suspension/227867-spc-front-and-rear-camber-kit-unreal-deal-save-your-tires.html
what is the difference between the adj camber arms and the kit w/ just the bolt?
which one do I need?
the front is ok, so i dont think ill get the control arms.
thanks everyone
thanks everyone
Just go with the SPC rear camber arms and toe bolts. It all comes in one kit for the rear only. I bought mine for $130 shipped. Most people I've seen on here, this is what they use.
https://my350z.com/forum/showthread.php?t=227867
Rear Adjustment range: Camber ±4.00¡ Toe ±3.00¡
Installation time: .6 hr/side
Required: 1 kit per wheel
Applications
Nissan: 2002 & Up 350Z
Originally Posted by Cloud
Has anyone come up with a toe solution for a non full coilover suspension without having to do any cutting/dremeling to the car i.e toe bolts?
Originally Posted by redlude97
there is no correct way to adjust the camber without doing this.
The real way to adjust camber would be to adjust through the rear upper control arm (RUCA) but we do not have new RUCA's available on the market. Changing camber through the RUCA will not affect toe
So for now, we are all stuck with using the camber and toe arms.
Here is a slightly old picture of the first prototype. They have been revised slightly since then and should be released for sale next week.
Originally Posted by tommyjeans214
hey all
thanks everyone
thanks everyone
you should go over your install or have an experienced shop go over your install for you, as something is wrong. At their highest settings, the HKS RS are just about at stock height
Given the low price, strength, and ease of install, the SPC kit is your best bet, bar none
The most simple kit is the SPC camber arms with the toe bolts. You can get the Eibach kit too because it's the same SPC arms and bolts and can often be found for less money. It's no big bead to use a dremel to elongate the toe bolt holes. It shouldn't take more than 10 minutes total.
bcoffee20
Nov 19, 2015 06:39 PM
