View Poll Results: Brake Discs: Drilled, Slotted, Both, or Neither?
Drilled
23
10.09%
Slotted
89
39.04%
Both
84
36.84%
Neither
32
14.04%
Voters: 228. You may not vote on this poll
Old Jun 21, 2007 | 06:43 AM
  #41
Kolia's Avatar
Kolia
Originally Posted by Apanther
You know what I just thought about.....my streetbike, and pretty much all motorcycles have drilled (or holed) rotors. and I know the braking on a bike is more intense than a car.
Any perspective on this?
A motorcycle weight close to 500lb with a rider yet the front rotors are often larger than the ones on a car. Pads are smaller though. Comparing that to a 3,400lb car only means the bikes brake need to work ~6 times less hard than the ones on the car... More intense ?
Plus, the cost of one bike rotors is often more than a full set of good rotor for the Z...
Old Jun 21, 2007 | 07:48 AM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by Kolia
Comparing a BBK with larger rotors, and different pads to the OEM setup to back up a claim that slotted rotors don't generate more dust than plain? Come on... Apple and oranges...
I don't think its necessarily apples to oranges. Your statement that slotted rotors produce more dust had no caveats in it...it was as general, and broad of a statement as you can get. As such, my reply, though annecdotal, was similarly broad based. My Z should have the propensity towards more brake dust by your theory, based on the fact that its got a far larger pad than my Audi, slotted rotors (vs solid on my Audi), and pads that generate a far higher coefficient of friction vs the stock pads on my Audi. Yet the brake dust produced by my Audi in a 100 miles of use is equal to what shows on my Z after roughly 400 miles. My point is that yes, of course a slotted rotor produces dust - as does a solid rotor. However I disagree that given similar pads, and similarly compounded rotors, one produces more dust vs another. You can't make that type of statement without knowing the properties of each material involved. It's the nature of two materials, especially those designed to cause friction, rather than prevent it, rubbing together.
My only bone of contention (for lack of a better phrase) is you seem to be saying is that your way is better. It works for you...cool, more power to ya. Your going a bit further than merely "this is what I run and why". You are insinuating your way is better, but its based largely on your opinion, which I don't think any data shown to date, necessarily proves. Your links and opinions have shown that yes, your way is working for you, given your set of circumstances. Others posts have shown that there are other setups that work too. Which works better? That would be quite an involved "test" so I don't think it's likely we'll ever get those results. There are different ways to skin a cat.
My ITS BMW runs slotted rotors and Hawk Blue pads - I change pads 1 x per year, and have not changed rotors in 2 years. I wonder why I get such great rotor and pad life? My guess is the car weighs the minimum amount (I have to add weight), and runs Hoosiers.
I think you are taking disagreement too similarly to personal attacks - no one is personally attacking you at all.
Old Jun 21, 2007 | 07:58 AM
  #43
push's Avatar
push
x2
I don't think that slotted is the only way to go with a rotor on a track car, obviously some track cars are using drilled and some blanks. If blanks work for you that's fine, I just don't feel a blank is superior to a slotted when it comes to the track. Some of my theories may be wrong, but I'm on this board to learn, and if I come back learning just one more thing about brakes it makes this all worth it.
Old Jun 21, 2007 | 08:07 AM
  #44
Kolia's Avatar
Kolia
The whole discussion is focused on the use of slotted, drilled and plain rotors.
I agree that the system has to be taken as a whole at some point. But since the current discussion is focused on the rotors themselves, there is no reason to bring different uses and application in perspective when comparing "dust production capabilities".
I would find it hard to believe that in a "dust test", if such a thing did exist, performed on one car in controlled condition with plain vs slotted rotors, the dust production would be equal... Common sense and general consensus points to that too (ie slots are better because the clean your pads). You can't accept one without the other!
Of course I think the direction I've taken is the best for me. What sort of a stupid person would I be otherwise?
Hey, anything can "work". Nobody on the street ever use their brake system at 100%.
It's my understanding that your Audi is a track car? And that you run solid rotors on that car? Interesting...
Old Jun 21, 2007 | 08:13 AM
  #45
push's Avatar
push
No one is saying they wont dust more, but you paint the picture you will be going through pads like a woman at that time of the month, which isn't true. Several people who have run and are still running slotted rotors have straight up said there is barely in difference in pad life/dusting. I had slotted rotors on my prelude back in the day and had no problems with decreased pad life. I'm putting a set on my z soon, and I will see how long they last.
Old Jun 21, 2007 | 08:16 AM
  #46
Z1 Performance
Former Sponsor
No, my Audi is my daily driver (dd)
Again, I didn't bring the dust issue into it, you did. I simply was sharing my annecdotal experience, just as you are, between my daily driven Audi, with a complete OE setup using solid rotors and Audi's OE pad, to my often driven Z, with a big brake kit (bigger pad), using slotted rotors, and pads that are considered (by the manufacturer) to be both street friendly, and track-able (I have not tracked the car yet with these pads).
My previous setup (a different BBK) used both slotted AND drilled rotors, and I experienced no compromise in pad life (used both DS2500's and Porterfield RS4 (or R4S...I always forget the name). In fact, that first set of brakes was used (on a Z32 twin turbo), and had gone through quite a number of track days even before I got them, yet I never had a crack in any of the holes (not using any cooling ducts either), and did quite a number of track events myself.
My other car, and older Datsun (with a bunch of power) uses x drilled rotors at present, with this pretty funky pad (that is no longer made unfortunately), and while I never tracked it, it's gone 5 + years without ever cracking a rotor (the stops I do on that car tend to be from 120 + down, as it's really a top end type of setup).
Old Jun 21, 2007 | 08:32 AM
  #47
Kolia's Avatar
Kolia
Why do you guys not want me to say that plain rotors are better overall? They are!
Pad matching is of the outmost importance. That is what will affect the feel and performance of the brake system the most.
The discussion slid toward dust production. But please, remind me again what the advantages of running slots are? I'll be surprised if "Run the right pad" doesn't cancel the issue/performance gain we might get with the slots each time...
Evacuating gases? - What gases if the pad is designed for the temperature range?
Deglazing pads? - What glaze if the pad is designed for the temperature range?
Cooling? - Over heating won't be an issue if the pad is designed for the temperature range.
Better initial bite? - I have more than enough with the pads I use.
Better drying after driving thru water? - A slight brake pressure will fix that
What else?
The OP asked what we preferred. I prefer plain for the reasons I gave.
Old Jun 21, 2007 | 08:46 AM
  #48
push's Avatar
push
What else?
Better initial bite: You are admitting that slotted offers better bite. Saying you don't think you need it because you have enough as is doesn't change that.
Drying: Adding brake pressure will fix it, but you have to worry about it less with slotted. Once again, doesn't matter if you think it's important or not, slotted does it better.
Old Jun 21, 2007 | 09:42 AM
  #49
Kolia's Avatar
Kolia
Does the drying power of the slots enough to eliminate the need to dry the rotors? In other words, do you still need to tap the brakes? I certainly would, regardless of the rotors I use.
Initial bite, I say I have enough because I can lock the wheels if I brake too hard before the height transfer is initiated. There is zero gain on my application in that situation. I'd still have to wait for the car the settle itself before I can maximize my braking.
These certainly don't justify, IMO, the extra expense of slotted rotors. The extra wear on my already short lived pads is not wanted either.
I've said it before, other applications can work. The main reason most people eventually go with drilled or slotted is aesthetics. Which is perfectly fine. An other one, for slots, seems to be to extend the performance envelope of a inadequate pad. That's ok also I guess.
Old Jun 21, 2007 | 09:57 AM
  #50
Kolia's Avatar
Kolia
I can't help but think that if I had said "Slotted rotors are the best thing eva'", nobody would have said anything against me...
Certainly no comment in the lines of "Well in certain situations, plain (or drilled) would be preferable"...
lol
Old Jun 21, 2007 | 10:40 AM
  #51
350Zenophile's Avatar
350Zenophile
I read a recent review of the ipd volvo s40 in SCC that complained of a whooshing noise from the brakes. They attributed this to the addition of slotted rotors. Any truth to this?
Old Jun 26, 2007 | 03:03 PM
  #52
sno's Avatar
sno
I read the whole thread; good info. Thanks guys.
Old Jul 10, 2007 | 03:58 AM
  #53
dieselmcore's Avatar
dieselmcore
GREAT INFO NOT GOOD INFO !!
Old Jul 10, 2007 | 10:41 AM
  #54
rcdash's Avatar
rcdash
What else?
Good post. I didn't mean to attack you before, just diagreeing with some of your reasoning and adding a little humor - my apologies if it came across that way.
Old Jul 11, 2007 | 11:05 AM
  #55
SS21CA's Avatar
SS21CA
This issue is always a toss-up IMO. My next set will most likely be a quality set of drilled rotors.
I would just recommend you stay away from EBC rotors from my experience. They are slotted and dimpled, but make a ton of noise. Most notably while driving.
Old Nov 20, 2007 | 05:23 AM
  #56
jdepe's Avatar
jdepe
slotted rotors FTMFW all day. its been proven that drilled rotors crack under track conditions. =D but if you just drive your car on the street and dont auto x then who cares. imo slotted
Old Nov 20, 2007 | 07:36 AM
  #57
Z1 Performance
Former Sponsor
no, what's been proven is that no name rotors by no name manufacturers, no matter slotted, drilled, or solid are not trackable...and that a quality rotor, from a quality manufacturer, is. Please lets not get into a slotted vs drilled debate...there are plenty of cars....track cars, that use a drilled rotor, plenty of factory sports cars that come with them, where people track them, and aren't cracking rotors left and right.
Stick to a known brand, and get pads that will play nicely with the rotors you intend to use, and you'll do just fine
Old Nov 20, 2007 | 09:36 AM
  #58
VO...'s Avatar
VO...
Administrator
Originally Posted by behjjeh
for looks = Drilled/Slotted
for track = Slotted
for normal driving = Neither
+1
I have all drilled on all 4 rotors, but it's for show only...
Old Nov 20, 2007 | 02:02 PM
  #59
Lawn Dart's Avatar
Lawn Dart
Originally Posted by StopTech
The ONLY reason porsche sells cars with drilled rotors is for appearance purposes and the race car look they offer.
The "Porsche 911 Story" by Paul Frère states otherwise, "...these drilled discs ran cooler, were noticeably lighter and provided better wet weather response, as any water was forced into the holes at the first application of the pads." He also said, "Instead of being part of the disc casting, the holes were drilled and their extrememities recessed for better evacuation of brake pad dust which was prone to be baked and to clog the holes."
Therefore, Porsche does not include drilled rotors purely for looks and the holes in their discs are drilled, not cast.
People are quick to point out that drilled rotors crack. Actually, all rotors are prone to cracking. Above is one of my own rear non-Brembo 350Z rotors. I replaced my rotors around 52,000 miles. Notice the giant crack through the drum area, obviously damaged by heat from the emergency brake. Drifting is hard on e-brakes.
Here is another image of cracks on the contact area of a plain rotor. People are quick to point out that drilled rotors are prone to cracking. However, what do you think the specific threats of a cracked rotor really are? Exploding rotors? Instant wheel lock up? I doubt it. Probably a little extra brake lining wear. Whoopty doo.
Old Nov 20, 2007 | 02:22 PM
  #60
The_VQ's Avatar
The_VQ
Are there any "drilled" rotors where the holes are actually cast not CNC drilled?
