Where Should I Set My Alignment At
Old Jun 25, 2007 | 05:44 PM
VIZAGE's Avatar
VIZAGE
Question Where Should I Set My Alignment At
I'm going to go for my alignment this weekend. Just put on Eibach prokit and it is now settled. I'm only referring to the rears for that I bought adjustable camber arms and toe bolts. I have nothing for the fronts yet. But what should I tell the guy doing the alignment to set the rear camber and toe to? Will not be tracking but a little bit of drag racing a couple times a month. Looking for a good even tire wear. Thanks ahead of time.
Old Jun 25, 2007 | 09:09 PM
Gsedan35's Avatar
Gsedan35
Based on what you want, go to the minimum negitive rear camber spec of -1.0 as long as you can get -1.5mm total rear toe in.
Old Jun 26, 2007 | 02:08 PM
VIZAGE's Avatar
VIZAGE
Is -1.5 total toe the max. Last time I had an alignment the total toe was .20.
Old Jun 26, 2007 | 03:27 PM
redlude97's Avatar
redlude97
your alignment was in inches, Gsedan35 is giving you specs in mm's, do the conversion and you'll get the right value. My rear is setup at -1.6 camber and 0.05 toe
Old Jun 26, 2007 | 04:25 PM
VIZAGE's Avatar
VIZAGE
I knew that. I don't know why I didn't put 2 and 2 together. Thanks for bringing me back to reality. It's Monday.
Depravity
Oct 1, 2015 04:49 PM
