project mu pads problem
Old Jul 4, 2007 | 08:26 PM
tumzilla's Avatar
tumzilla
Default project mu pads problem
Got my front project mu nu pads installed and my front rotors resurfaced but now they squeak worse than before at low braking speeds. If I kinda hold the brake pedal when coming to a slow stop it makes a weird hollow sound or something. Anybody got any suggestions? Should I try using some anti squeal stuff ?
Old Jul 5, 2007 | 06:53 AM
THE TECH's Avatar
THE TECH
Just seems to be the nature of the PMU pads. Did you bed in the rotors/pads correctly?
Old Jul 5, 2007 | 06:55 AM
bb1314's Avatar
bb1314
da Terminator!
I have the B-force pads, they SQUEEAAAAK! I wonder if I didn't stall the pads correctly here.
Old Jul 5, 2007 | 07:08 AM
THE TECH's Avatar
THE TECH
I'm sure you probably installed them correctly. The B-Force just seem to squeal more than others.
Old Jul 5, 2007 | 07:14 AM
tumzilla's Avatar
tumzilla
No I haven't yet but I will tonight. I just saw something wierd this morning while looking at my front pads.
1. driver side - 1 brake clip normal and other is not clipped in?
2. passenger side - 1 brake clip not clipped in and the other is missing.
Did the shop where I got my pads installed do a sloppy job?
Old Jul 5, 2007 | 07:24 AM
THE TECH's Avatar
THE TECH
Sounds like it. I wouldn't drive the car.
Old Jul 5, 2007 | 07:29 AM
tumzilla's Avatar
tumzilla
so what should I do ?
Old Jul 5, 2007 | 07:30 AM
Richy350Z's Avatar
Richy350Z
take the car back?
Old Jul 5, 2007 | 07:32 AM
THE TECH's Avatar
THE TECH
Contact the shop first and foremost. Then I would have it towed back there.
Old Jul 5, 2007 | 07:33 AM
z-u-later's Avatar
z-u-later
Looks like they did not install & bed the pads properly. Return it and have them fix the problem. And don't go back after they fix the problem. I have these same pads and never have any problems.
tumzilla's Avatar
tumzilla
argggg thnx for the fast replies guys.
Old Jul 5, 2007 | 07:37 AM
shinkuu's Avatar
shinkuu
i installed b force pads myself with little squeaks during its life time.
i also bedded them in really good and completely wore them out in 6 track days. i've had no squeak problems with little dusting.
Old Jul 5, 2007 | 07:40 AM
tumzilla's Avatar
tumzilla
The squeaks are annoying but I am mainly just worried about the clips or maybe I'am just being paranoid.
Old Jul 5, 2007 | 08:03 AM
THE TECH's Avatar
THE TECH
You should be definitely worried if the clips are missing. You will have to bed the pads yourself as this is something a shop doesn't do normally.
Old Jul 5, 2007 | 10:14 AM
tumzilla's Avatar
tumzilla
sounds good
Old Jul 5, 2007 | 10:53 AM
Ztalker's Avatar
Ztalker
for peace of mind....always change my own brake pads.
those spring loaded clips are tricky to install correctly sometimes.
Old Jul 5, 2007 | 11:08 AM
tumzilla's Avatar
tumzilla
yea I need to learn sooner or later and brake pads should be the easiest thing to do.
Old Jul 5, 2007 | 11:19 AM
Ztalker's Avatar
Ztalker
it shouldn't take more than 15 minutes for each side if you got all the tools and brake cleaners ready. Takes longer if rotor replacement is involved. Nissan brakes are pretty straight forward unlike BMWs.
Old Jul 5, 2007 | 11:25 AM
r_seng's Avatar
r_seng
i had the B-force on my S13, they squeal, and its normal.
Old Aug 8, 2007 | 11:15 AM
PhiSig's Avatar
PhiSig
Wheel Whore
What does it mean to BED the break pads before you put them on?
