Cusco or SPL A-Arms?
Old Sep 10, 2007 | 06:34 PM
  #41
bikinilust's Avatar
bikinilust
Default <1"drop = Cusco / >or=1"drop = SPC
i have a 1.1"drop in the front and 1" in the rear (H&R g35 coupe)... I went with the Cusco because they were slightly cheaper, and i suspected that i wouldnt need that much adjustment because it was only a 1" drop... With that 1" drop, the Cusco's barely got me w/in specs.. The alignment shop put them to the max adjustment, and i was almost borderlined out of specs. Quality for quality, i believe that Cusco & SPC are very close to being the same. So it just depends on how much of a drop you are going with which will determine which is better for your application...<1"drop = Cusco / >or=1"drop = SPC
Old Sep 10, 2007 | 11:44 PM
  #42
WA2GOOD's Avatar
WA2GOOD
Thanks for the input............... But, I am pretty sure this thread is asking about, or comparing the Cusco to the SPL Parts adjustable upper controll arms. Not the SPC and the Cusco. SPL Parts is definately not SPC.
Old Sep 11, 2007 | 04:26 AM
  #43
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
i have a 1.1"drop in the front and 1" in the rear (H&R g35 coupe)... I went with the Cusco because they were slightly cheaper, and i suspected that i wouldnt need that much adjustment because it was only a 1" drop... With that 1" drop, the Cusco's barely got me in specs.. The alignment shop put them to the max adjustment, and i was almost borderlined out of specs. Quality for quality, i believe that Cusco & SPL are very close to being the same. So it just depends on how much of a drop you are going with which will determine which is better for your application...<1"drop = Cusco / >or=1"drop = SPL
because it will completely depend what your alignment specs are before any a arms are installed, which is directly related to your wheel and tire combo, and your factory alignment settings, which vary car to car.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
RiujinZero
Sep 25, 2015 01:19 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
