GT-Spec ladder brace exhaust clearance?
Old Jul 16, 2007 | 09:44 PM
MustGoFastR's Avatar
MustGoFastR
Default GT-Spec ladder brace exhaust clearance?
Anyone know what the exhaust clearance is on it? I have the Nismo exhaust, so that's larger than stock, and also had to space it down a bit at the rear brackets and B-pipe bracket to accomodate my rear skirt, so I'm a bit concerned about it possibly rubbing the brace if there isn't enough clearance. It's maybe an eighth of an inch lower than normal up where the brace will be.
Old Jul 16, 2007 | 11:23 PM
g35pm's Avatar
g35pm
I think you should be ok. I have a fuji exhaust and it cleared fine. I'd be more concerned with ground clearance. When I had this on my car, it scraped everything.
Do you already have the ladder bar? If so, it's an easy test fit.
Old Jul 17, 2007 | 06:07 AM
THE TECH's Avatar
THE TECH
If you're referring to the 4pt brace, you should have no problems.
Old Jul 17, 2007 | 08:56 AM
MustGoFastR
Yeah, the 4 pt. brace. I'd think I should be ok scraping-wise; my car isn't a DD and I don't drive it anyplace that my front lip will scrape, anyway.
Does this brace make that big of a difference? I have Nismo suspension, sways and the F/R tie braces right now (freaking wish they would make a R lateral brace that would fit with the Nismo exhaust).
Old Jul 17, 2007 | 09:12 AM
THE TECH's Avatar
THE TECH
I didn't feel any difference with it.
Old Jul 17, 2007 | 09:21 AM
GTSPEC's Avatar
GTSPEC
GTSPEC
The new version 2 braces will be released shortly. And yes they will work with the NISMO as well as True Dual 3" exhausts
Old Jul 17, 2007 | 12:37 PM
MustGoFastR
Sweet! This an update to the lateral brace only (rest will remain the same)?
Old Jul 17, 2007 | 12:48 PM
350Z84's Avatar
350Z84
Sweet, any idea when this will be released?
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
