Front Brembo brakes on the rear
Old Jul 20, 2007 | 10:59 AM
topnotch350z's Avatar
topnotch350z
Default Front Brembo brakes on the rear
Has this been done or even possible to fit the front Brembo brakes on the rear as an alternative to buying a BBK for the rear when somebody buys the front?
Alang35's Avatar
Alang35
the bias will be all messed up. i would say thats pretty unsafe
Old Jul 20, 2007 | 12:06 PM
97supratt's Avatar
97supratt
It won't fit, the brackets don't lineup.
Old Jul 20, 2007 | 12:12 PM
topnotch350z
If one were to fabricate some custom brackets would it be possible to make it work? Alang35 said the bias would be messed up but i dont see the difference in rear BBK's except that all the hardware that come with them are made for the rear so why wouldn't somebody be able to fabricate customer hardware to retrofit the fronts on the rear?
michaeljr6's Avatar
michaeljr6
uhhhhhhhhhhhhhhhhh lol..
Old Jul 20, 2007 | 12:17 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
I think you should do some more research on BBK's.
The front piston sizes on the factory BREMBO caliper will have way too much torque output for the rear axles. Fabricating a bracket to make it fit wouldn't be a problem but what would you run in the front? You would need some serious brakes in the front to match the brake bias of putting the BREMBO caliper in the rear which is way too much braking force thats needed for the Z.
Old Jul 20, 2007 | 12:26 PM
izmir41500's Avatar
izmir41500
of course your brake biased will be jacked. the area of the pad will tell you that.
Old Jul 20, 2007 | 12:30 PM
topnotch350z
I guess I should have been a little more clear with what I had in mind. My question was answered that yes it's possible to fit the front Brembos on the rear and so far the biggest BBK for the front is the Rotora 8-piston correct me if I'm wrong?
Old Jul 20, 2007 | 12:31 PM
gqong's Avatar
gqong
rotora has 12-piston
Old Jul 20, 2007 | 12:38 PM
topnotch350z
Even better...thank you gentlemen my question has been answered.
Old Jul 20, 2007 | 12:40 PM
Andy@Performance
Performance Nissan
So you would run a Rotora 8 piston front and a BREMBO 4 piston rear? Just because you're running a 8 piston caliper doesn't mean that the bias will be balanced. Take a look at Rotora's 6 piston caliper compared to a STOPTECH 4 piston ST40 caliper. The ST40 caliper is almost similar in size to the Rotora 6 piston, why?. STOPTECH's ST40 caliper consists of bigger piston sizes compensating for the size difference of the caliper. Its the piston sizes that makes a difference in the torque output of the caliper. If you're serious on dropping some cash on this custom setup, I'd research to see exactly what torque output rating the front caliper will have compared to the BREMBO 4 piston that you want to use on the rear. If you don't really care about the brake bias and the balance of your braking system, than this custom setup can be done. Have a machine shop fabricate you a caliper bracket for the rear and I'm sure you can piece all the hardware together.
Why not just get a BBK that runs a 4 piston rear caliper? The costs of making this custom brake setup to work properly will probably cost more than just buying a 4 wheel BBK.
Old Jul 20, 2007 | 01:26 PM
97supratt's Avatar
97supratt
Research goes a long way these days. lol
Old Jul 20, 2007 | 03:05 PM
StopTech's Avatar
StopTech
Vendor - Former Vendor
I had a chance to look at some of the numbers involved with this. As a start, the front calipers have about 50% greater torque output than the rear calipers which is a significant amount. Going from a mellow street pad to a very aggressive track pad is about a 5% shift so these are huge numbers. In order to maintain balance with the front brake system on the rear of the car, you would need to increase front brake torque by double and that basically means maxing out the piston sizing on our 6 piston caliper or trying to mount 2 stock front calipers onto the front rotor.
After all this work, custom parts, and engineering, what do you get?
1: A super long soft brake pedal that is very grabby with the only fix being a new VERY large master cylinder
2: A completely useless ABS and VDC system because the computer cant adjust to such a drastic change.
3: No parking brake since the front rotors wont clear that setup.
4: Basically the same balance as stock so no improvement in stopping distances
5: Zero increase in front heat capacity since the rotor size has not increased and only an incremental increase in rear heat capacity which isnt even an issue on the factory Brembo setup to start with.
So the easy answer is no, dont do it, its not worth it. There are plenty of cheaper, easier and better options out there, many of which we already offer
Old Jul 20, 2007 | 03:14 PM
1nate7's Avatar
1nate7
Good stuff, it's nice to have vendors like Stoptech on the boards.
Old Jul 26, 2007 | 10:06 AM
Alang35's Avatar
Alang35
yep, companies like stoptech pour a lot of money into testing and making sure everything works together safely. why would you attempt to do this on your own resulting in something expensive and unsafe?
Old Jul 26, 2007 | 10:14 AM
fast kiwi's Avatar
fast kiwi
listen to this advice.. its very sound.. but then.. your the one with the money..
Old Feb 26, 2008 | 07:35 AM
michaelm5's Avatar
michaelm5
The first post had the correct answer, "the bias will be all messed up" then Stoptech validates this with a complete accurate description of what you would have. You need to install a system or leave it alone.
samansharif
Sep 25, 2015 12:31 PM
