Wheel hop! How to eliminate?
Old Jul 26, 2007 | 06:14 PM
myG35zx's Avatar
myG35zx
Default Wheel hop! How to eliminate?
How can I limit or eliminate wheel hop on these cars? My 2003 coupe had no wheel hop (stock or eibach). The 2005 sedan does(stock and see signature).
Old Aug 1, 2007 | 12:11 PM
mgtibbetts's Avatar
mgtibbetts
My wheel hop went away after I put in the cusco rs 1.5 way diff.
Old Aug 1, 2007 | 02:26 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Check out these links about the InGalls "Stiffy" ETD:
- https://my350z.com/forum/showthread....hlight=InGalls
Old Aug 1, 2007 | 05:21 PM
myG35zx's Avatar
myG35zx
I'm not sure how either will help. I'm not saying they don't, just I don't understand.
mgtibbetts:
When you would lose traction prior to the LSD, would the rear begin hopping? Then after the LSD install the hopping did not occur? Either when heating up the tires at a strip or when traction is lost, my car hops enough to shift the car out of gear! (long story, embarrassed )
Robert K:
Did you have wheel hop before the install and it was eliminated by the stiffy ( )?
Old Aug 1, 2007 | 06:42 PM
Nexx's Avatar
Nexx
have you tried running less air ?
Old Aug 2, 2007 | 03:58 AM
myG35zx's Avatar
myG35zx
I'm down to 34 pounds in each tire. I'll try 27. My concern then becomes treadwear though.
Old Aug 2, 2007 | 04:30 AM
Plenty of ongoing discussion in the drag racing forum. I say the wheel hop is the result of poor technique. You are not applying sufficient power to the rear tires. The tires spin, grab, spin, grab… causing the rear axle to hop.
Fix your technique – fix the wheel hop.
Old Aug 2, 2007 | 05:33 AM
myG35zx's Avatar
myG35zx
Thanks.
Old Nov 6, 2007 | 07:37 AM
nearly zer0's Avatar
nearly zer0
I have wheel hop problems on my z as well and while proper driving technique may eliminate the problem the bottom line is that I don't want my car to have wheel hop at any time, ever, no matter what I'm doing to it. What products are available to correct this that actually work? I have a set of solid rear diff mounts sitting in a box, but I'm not sure I want the additional cabin noise that these will bring.
Old Nov 6, 2007 | 08:13 AM
DouBLeJ16's Avatar
DouBLeJ16
Awesome product.. I had one on my scion tc and the difference was night and day. Only thing that sucks is you can't adjust it on the car, you have to remove it and reinstall it to adjust. When it was on the stiff setting my dash would vibrate at idle, it was very annoying.
I attempted to adjust it on the car once and ruined the piece.. Ingalls was very cool and sent me a replacement for free.
Old Nov 6, 2007 | 08:40 AM
nearly zer0
Do you have one on your z? If you had wheel hop before did this correct it?
I can appreciate stiffer motor mounts, but I'm not sure how this could possibly eliminate wheel hop.
Old Nov 6, 2007 | 08:48 AM
myG35zx's Avatar
myG35zx
I'm no expert (at anything ) but I can't see how anything other than the rear suspension/geometry effects wheel hop. It's strange that my 2003 G Coupe had no wheel hop, but the 2005 sedan does. Changing the springs, shocks, camber arms... did not affect either car. I understand about changing the launch technique. But how do you change your burnout technique? I can't spin the tires at all without massive hop (and not the good kind that Lebron has).
Old Nov 6, 2007 | 07:44 PM
nearly zer0
I guess i'll put in the solid diff mounts to see if that works. It is getting cold out here and I hate working on cars though. I wish there was a decent shop close by..
Old Nov 7, 2007 | 07:17 PM
Abishop's Avatar
Abishop
Keep in mind your TC was FWD. this damper only stabilizes the engine. To reduce wheel hop, get a bigger sidewall tire, run lower pressure, or set up your rear suspension for the track your launching at.
Old Nov 13, 2007 | 06:22 AM
nearly zer0
No one has an answer to this?
Old Feb 27, 2008 | 04:18 AM
nuclearcarnie's Avatar
nuclearcarnie
I have to bump this one up. I have been asking the same question about wheel hop for a while on more than one forum and can never get a definative answer to what will stop this. Technique is not the answer I am looking for. I have owned plenty of hot rods in my life and have always been able to remedy the hop with traction devices of some sort, is there nothing that will fix this problem?
Old Feb 27, 2008 | 04:25 AM
nearly zer0
solid rear diff bushings, aparently, is the answer.
i happen to have a set that i never installed on my Z. my car is on the for sale market now so I'll be selling the extra parts I have. I also have a set of new rear Koni adjustable shocks that can give you stronger dampening as well
Old Feb 27, 2008 | 04:26 AM
nearly zer0
Here is a link to the SPL bushings: https://my350z.com/forum/showthread....d+differential
Old Mar 2, 2008 | 09:02 PM
nuclearcarnie
Thanks for the reply, it is much appreciated!
Old Mar 2, 2008 | 09:04 PM
mgtibbetts's Avatar
mgtibbetts
Still say it's the stock viscous LSD. I don't think it puts down consistantly to both wheels with the power involved in spinning the tires from a standstill. Think about it, the tires grip and slip and grip and slip causing the suspension to bounce up and down. I had less hop on stock tires, got worse with wider stickier tires. Soon as I put in my cusco 1.5 way, no more hop.
