Wheel hop! How to eliminate?
Old Mar 2, 2008 | 10:00 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by Nexx
have you tried running less air ?
This only truly matters when you have over-inflated your tires. Stock pressure shouldn't give you too much trouble.
Originally Posted by davidv
Plenty of ongoing discussion in the drag racing forum. I say the wheel hop is the result of poor technique. You are not applying sufficient power to the rear tires. The tires spin, grab, spin, grab… causing the rear axle to hop.
Fix your technique – fix the wheel hop.
I'd think it's the opposite. Too much power will result in greater slipping of the tires, thus burnouts. By applying less power to the wheels while increasing throttle gradually, the wheel hop can be eliminated as your tires aren't overpowering the grip with the initial bite.
I'd assume the best physical change you can make, excluding to your own driving technique (which should be your priority), would be suspension mods. You would want your rear to squat down, but not spring up right away (which means less weight applied to the rear suspension, thus greater likelihood of wheelhop).
Old Mar 3, 2008 | 06:10 AM
nearly zer0's Avatar
nearly zer0
The worst wheel hop i had was always in the rain. I would accelerate from a stop, not trying to spin the tires, but would get obscene hop.
Old Mar 12, 2008 | 10:28 PM
jgregory124's Avatar
jgregory124
doesnt stillen makes a damper dont they?
Old Mar 12, 2008 | 10:43 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
^For the engine, not suspension
Old Mar 12, 2008 | 11:50 PM
alan86's Avatar
alan86
launch at a higher rpm your probably getting too much traction
Old Mar 13, 2008 | 09:31 AM
3hree5ive0ero
Retired Admin
Too much traction would equate to tires sticking to the ground, thus being able to put more power to the ground. That means, tires are gripping and not slipping.
He's getting alternating traction (on off on off on off). The best remedy would be to learn to control your launch better. It's probably easiest to start at a lower rpm when launching, so your tires have a greater chance of gripping from the less power applied.
Old Apr 24, 2008 | 04:51 PM
n350zismo's Avatar
n350zismo
Ive got a vid of a launch I did with no wheel hop. Check it out.
http://youtube.com/watch?v=Yf0gMeoWSQM
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
