BBK Abs
Old Aug 5, 2007 | 07:55 PM
saladito6's Avatar
saladito6
Default BBK Abs
Do Big Brake Kits utilize the stock ABS on the Z?
Old Aug 6, 2007 | 04:50 AM
Z04's Avatar
Z04
yes
https://my350z.com/forum/showthread....th+a+brake+kit
Old Aug 6, 2007 | 06:59 AM
THE TECH's Avatar
THE TECH
You'd have to run all new brake lines if you wanted to bypass the ABS system.
Old Aug 6, 2007 | 07:45 AM
saladito6's Avatar
saladito6
Thanks, it was a relatively easy question to answer, but I just saw on some of the 6POT systems for Stoptech, the specs dont say they are ABC compatible, and the other 4POT kits say they are. That is why I asked, thanks for clearing things up though.
Old Aug 7, 2007 | 07:43 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
Both the 4 piston and the 6 piston big brake kits are ABS compatible. What you gain with the 6 piston are the looks and more heat capacity because of the larger pads. This usually translates to longer life of components as well.
aarrgghh
May 1, 2022 11:04 AM
seagrasser
Oct 11, 2015 03:27 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
