Is my front alignment no good?
Old Aug 16, 2007 | 03:05 PM
Tac-M's Avatar
Tac-M
Default Is my front alignment no good?
I have my z dropped on Eibach Coilovers, the height is identical on bouth sides , but my front camber is way different.
Any ideas, besides getting a - arms?
Old Aug 16, 2007 | 03:07 PM
gdup35sedan's Avatar
gdup35sedan
0.5 Cross camber is fine. You could get the arms to make them perfectly even, but you dont need to.
-GP-
Old Aug 16, 2007 | 03:12 PM
Tac-M's Avatar
Tac-M
Thanks GP !
BTW~ is this ok for a nuub? http://www.tamron.com/lenses/prod/1750_diII_a016.asp
or would i have more fun with this ? http://www.tamron.com/lenses/prod/11_18mm.asp
Old Aug 16, 2007 | 03:17 PM
gdup35sedan
Originally Posted by Tac-M
Thanks GP !
If you're new to photography, i'd definitely start with the 17-50 f2.8, i have the same lens in my arsenal and i absolutely love it, great lens for the money!
-GP-
Old Aug 16, 2007 | 04:36 PM
redlude97's Avatar
redlude97
is that with or without you in the car? When you get in, the left side suspension will droop some more and increase the camber on that side anyways. I would be more worried about the rear, that is quite a bit of negative camber
Old Aug 16, 2007 | 05:21 PM
Tac-M's Avatar
Tac-M
That’s without me in the car… so you are correct it gets worse with me in it.
The rear will be fixed ! I just rolled my fenders so I can finally fix that....
Old Aug 28, 2007 | 10:51 AM
PPWZEE's Avatar
PPWZEE
so you rolled the rear fenders? does that mean that you could have put the rear toe with in specs but your wheels/tires would not let you??? I want to get these springs on my z and i like all the specs except for the rear camber.
kyin
Oct 15, 2015 05:54 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
