True Coilovers - Are They Dangerous?
Hi All,
With true coilovers such as Stances where the OEM spring and shock is removed, replaced with a single spring/shock setup. Question is, with all the weight and pressure all on the brace (picture #1) and bushing(picture#2), will this be dangerous in the sense that the shock push right through the brace as illustrated in the photo?
What are the long term affects of having coilovers and potential hazards with this setup and removal of the OEM spring/shock absorber?
Coilovers are the best way to go in any situation (besides factory suspension of course). To answer your question: No it will not harm your car in any way; you shouldn't worry about the coilover doing harm to your car, but the car doing harm to your coilovers. The body will always stay the way it is; the coilover however, breaks down overtime (leaks, pressure, etc), so make you check up on them every 10k-20k miles or so.
Also you can adjust height with coilovers which factory suspension nor aftermarket springs cannot do
I know chances of failure are slim, but I wouldnt sway away from the factory design. I know drift teams use that but its just my opinion. You also always hear/read of true coilovers creeking and rattling in the rear, makes you wonder how long those bushing will hold up with added stress. Good luck making a decision.
if real race car drivers, drifters, autocross racers use coilovers, im sure coilovers are safe for daily street driving.
usually popular coilover companies have other users that have tested the products way harder than you may ever drive.
so, im sure it would be safe if you are not buying from some chinese ebay company. Stick with the most popular brand names. safety first, performance 2nd!
If you are happy with the ride height and ride quality of your current springs, you might want to just consider a high quality shock absorber. Or a matched set of springs and shocks with the rates you want.
And any shock absorber will leak over time.
The weakest point would be the two studs they would bolt up to in the top of the wheel well... I have seen a few pull out before... to replace properly, got to rip apart the whole rear quarter of the car...
Buy some springs and some Yellows.
/thread.
Race cars are under stress but race on FLAT, smooth surfaces. We see joints, potholes, rough roads that race cars arent subject to, and I think that could lead to a problem. The point brought up is also valid that they inspect/change components all the time, most of us arent jacking up the car to check on our coilovers. I broke a camber rod hitting a bad joint on a bridge in my Z years ago, almost lost control. Not a typical issue but the street can be brutal in different ways than the track.
To the original poster............
I vigerously track test and road test alot (if not all) of the aftermarkets coilover systems so much lately that a few companies actually work with me and send me thier products to independently test for them and to help them devolpe better products as well as implement changes in thier existing products. I can confidently say that you should have NO problem with the true coilover system on your Z. I beat the hell out of these in real world conditions as well as some high "G" load track sesions. After track testing almost every suspension product under the sun for these Z's and G's for over 4 years I have seen what works and what doesen't. We have had a set of true coilovers on our Time Attack race car for over 2 years now with absolutely no excess wear, and trust me this car gets beat on.
SCOTT @ RELENTLESS AUTOSPORTS -- Still Building the fastest Daily Driven & Track Proven Z's, G's, FX's, EVO's, TC's, and more!
The only thing that I can disagree with is the fact that racecars tend to rack up miles A LOT slower than your average daily driver. This means that the actual real world effect might be worse than what you see on a track car.
Originally Posted by jimmyloose
Some of the most successful race teams run spring/shock setups (SCCA T2 anyone?) that will outhandle most of those bull**** coilover setups anyday.
/thread.
/thread.
T2 springs are too stiff for off the shelf yellows.
Originally Posted by Axelerate
No, they run double adjustable, customed valved Koni's with T2 springs. Some run the set-up on a threaded strut, hence it's a "coil-over."
I thought this thread was a discussion of the 'true rear coil-over' setups championed by some of the companies out there.
I was just about to post something to that effect. Racers run on smooth (for the most part) surfaces. You've got tons of obstacles and crazy terrain to handle in real life.
I have DA TC Kline Koni's and T2's. I guess you could run a threaded perch on the rear, but what's the point there? The rears already sit too high.
