product test - TNS brake caliper heat sheilds
Old Aug 24, 2007 | 12:57 PM
calebmilla's Avatar
calebmilla
Default product test - TNS brake caliper heat sheilds
I installed the TNS brake caliper heat shields before the track day at the mid-ohio race track. They worked pretty good. I didn't have any problems with my brake fluid boiling like I usually do.
Old Aug 24, 2007 | 01:42 PM
THE TECH's Avatar
THE TECH
What do these do exactly?
Old Aug 24, 2007 | 02:43 PM
SuperBlack350z's Avatar
SuperBlack350z
i'm guessing it blocks the heat from the rotors?
Old Aug 24, 2007 | 02:46 PM
XuperXero's Avatar
XuperXero
looks like pad shims to me. A better option than OEM one...
I have noticed a dramatic difference between running with Pad shims and running without. Running with pad shims definitely prevents your brakes from going on fire!
Old Aug 24, 2007 | 04:14 PM
Morris's Avatar
Morris
What are these? How do they work? Where do I get them?
Old Aug 25, 2007 | 04:19 AM
calebmilla's Avatar
calebmilla
Sorry for not writing more. They stick to the back of the brake pad so the heat from the brake pad is blocked from going straight into the caliper. Normally the heat is transfered directly into the caliper since the caliper's pistons press against the back of the brake pad. They're very similar to shims except they aren't metalic and they don't transfer heat at all. I got them from TNS directly, their email is tnstuning@hotmail.com.
Old Aug 25, 2007 | 04:31 AM
Morris's Avatar
Morris
Thanks for the info. I will check them out.
Old Aug 25, 2007 | 05:17 AM
calebmilla's Avatar
calebmilla
Here's a pic of them installed and after 3 track days of abuse.
issyz
Jul 2, 2017 03:04 PM
