Kinetix traction rod cracked!
So my car is at Corner 3 Garage today getting a BBK installed when Steve noticed my traction rod in the back was cracked!!! WTF how does this happen?
Will post pics of the rod when I get the car back....
Has anyone else had this happen?
Originally Posted by redlude97
why are you using the traction rods in the first place?
Heres a couple pictures of the rods, the left one was completely snapped and the right one has a hairline crack on the welds. Ill def be contacting Kinetix about it but I wanted to give people here on the forum a heads up in case they are running early production models of this product.
This one was on the left
Right
Id like to give a big thank you to Steve at Corner 3 who caught this while doing my rear brake lines and possibly saving my life!!
Right
Originally Posted by ___DJK___
dunno, I got these like 4 years ago, supposedly they were supposed to help with wheel hop...
Did you adjust the length to see if there was a difference in your wheel hop? Did you also have toe bolts to correct for the toe change these arms affected?
Kinetix does have good customer service, they will be shipping me out a new set that is supposedly built a lot stronger.
THe new ones are black, and hopefully they dont crack. I had a set crack on me years ago but I was going 80mph and hit a joint on the highway when it happened. Almost lost it, drivers side rear wheel had like -7 degrees camber about to fall off. They sent new ones.
I think its fawked up they have had several cases and havent offered ALL of the customers with old traction/camber arms the newer ones...
I agree, something as dangerous as this should warrant a recall.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
