Brakes feel mooshi
So, recently i got into a small accident at the track. I came in too hot on a turn and smacked the left front side of the car.
The only damage was the fender and a snapped break line.
I just recently installed ss brake lines on all 4 and now the brakes feel weird.
During hard braking the pedal will descend all the way down.
When i push and hold the pedal down it gradually descends...isnt it supposed to be stiff?
When i pump the brakes while the car is on, the pedal gets harder, then starts to gradually go down...
My mechanic did the job so it shouldnt be due to a bad install (air bubbles in the system)
He tells me that it might be the master cylinder due to the brake line snapping and dirt getting in the cylinder.
What do you guys think?
You def have bubbles. You are suppose to bleed Right Rear, Left rear, RIght front, left front looking from behind the car. If you have oem brembos, you will have two air bleeders.
I think it's spelled mushy..lol.
Well, we did bleed both air bleeders on each caliper but did not do it in that order.
We did rf, lf, rl, rr..Does the order really matter?
