JIC FLT-A2 vs Tein Flex. What to buy?
Old Oct 12, 2007 | 11:41 AM
atownpdx's Avatar
atownpdx
Default JIC FLT-A2 vs Tein Flex. What to buy?
I have seen a lot of comments on Tein flex Coilovers, but not too much about JIC. I am looking specifically at a set of FLT-A2's. They're used with 1000 miles on them (so he says).
Anyone run these or used to run them? How do they compare to Tein. I looked at the website and the Teins are a bit stiffer, but the JIC are a lot more money at retail about 500 more.
Anyone know anything about JIC's?
Thanks
__________________
Atownpdx-05 Coupe 6MT DG
Old Oct 12, 2007 | 01:19 PM
Calvin@CRG's Avatar
Calvin@CRG
Temporary Disablement - Billing
im running the jics... theyre nice in my opinion. ive never had the flex on my z, but many of my friends [s13,evo...etc] run the flex. personally, theyre both good and cant go wrong on either. but for some reason ride is a bit more, for the lack of a better word, 'bumpy' with the jics... but it could be my dampining or something
Old Oct 12, 2007 | 01:25 PM
Chebosto's Avatar
Chebosto
theres gotta be like 100+ threads about this..
Old Oct 12, 2007 | 01:40 PM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
I prefer the flex over the FLT-A2's on a street car. The JIC's were a bit rough.
Old Oct 12, 2007 | 02:40 PM
laswyguy's Avatar
laswyguy
I have the FLT 2a.. they are a bit stiff for the street.
Old Oct 13, 2007 | 02:31 AM
Devil Z's Avatar
Devil Z
However FLT-A2's are DEFINITELY superior to the Tein for racing.
Old Oct 13, 2007 | 06:11 AM
Gsedan35's Avatar
Gsedan35
Well,...........having witnessed the Q&A session you did leading up to your purchase, you’re not qualified to make that statement.
Old Oct 13, 2007 | 07:23 AM
Jason333's Avatar
Jason333
hi
Maybe Alberto will chime in. He has had both.
Old Oct 13, 2007 | 03:38 PM
WA2GOOD's Avatar
WA2GOOD
I have ran both the JIC's and the tein's. Although I am not a fan of either one of these (especially for a street car), I would go with the stiff JIC's, Just get a back brace as well when you install them, Hahahaha
Old Oct 13, 2007 | 03:51 PM
Zilvia's Avatar
Zilvia
search and u will see
JIC pwn Tein
Old Oct 13, 2007 | 04:59 PM
John's Avatar
John
Both are junk. Lesser of two evils? Tein as the JICs are absolute trash unless on a perfectly smooth track. Do a search, and you'll see the nightmare experiences with the JICs - Teins don't have as many bad threads since they aren't tracked as much.
Best suggestion? Go with a set of Konis.
Old Oct 13, 2007 | 05:05 PM
Zilvia's Avatar
Zilvia
wow 1st i have ever heard of JIC being junk......
they just not the most streetable coilovers(any of them)
Old Oct 13, 2007 | 06:30 PM
John's Avatar
John
https://my350z.com/forum/brakes-and-suspension/56791-do-not-buy-anything-from-jic-usa.html
Search around here and other sites - you'll find out they're low quality dampers masked with high spring rates. I find it hilarious that I saw Jon K on TV the other day after he scams everybody on these products and also how he tried to scam me out of a bumper cover. JIC is an abortion of a company.
Old Oct 14, 2007 | 11:59 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I havent personally tried the FLT-A2's, but I have some people say they are bouncy, stiff, noisy..etc...etc. Others love them.
I have to be honest, in that most people that purchase fully adjustable coil-over setups rarely take the time to test-tune them on the track, and dial them in so that they compliment your driving style, tire package, and rest of the chassis. Most don't want to pay extra to have them corner balanced either.
I can't tell you which one is better, but I can tell you that we've been very pleased with TEIN Mono Flex's, and the SRC's on the track, and on the street. Are there better coilovers out there...absolutely so, and usually at much higher price. But characterizing Tein Mono's or Tein SRC as "junk" is not accurate, IMHO.
John, you are correct, in that TEIN uses a stiffer spring than most, but I feel their dampening is fairly good. And when running R-Dots, with a heavy car, they work very well. No significant bounce, that I can detect, and some of the tracks we go to have nasty surfaces, such as the old RA, the old RR, and CMP. I did take quite some time to get the setup to my liking, however, which is to be expected.
John is a very seasoned track guru, so he can probably turn good times, even with stock suspension and tires. Perhaps it would be better to spend some time on alignment, chassis setup..etc..etc. I am sure a good chassis guy could make any coil over work pretty darn well.
Old Oct 14, 2007 | 01:13 PM
redlude97's Avatar
redlude97
Better at racing into a guard rail right? Out of the body shop again yet Devil Z?
Old Oct 14, 2007 | 04:46 PM
1cockyZ's Avatar
1cockyZ
This might seem retarded but put flta2's spec'd for a g35 coupe on a z. Hard rubber rear mounts and softer spring rates. But seriously use the search function.
Old Oct 15, 2007 | 04:31 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Yup-I ran FLt A2's 10/12K for 30+K miles. VERY stiff on the street I swpped because at 30K the shocks were tired and they bounced too much. Even new,the dampening was lacking some. These coilovers once dialed in for me were good thoughbut had a NASTY tendency for snap oversteer at the limit, even when running front shocks at 7 and rears as soft as 2. Not very confidence inspriring but did handle well once you get used to them.
I now run 14/14k MONO Flex, and love them. Stiffer springs but they dont feel that way the dampening is much better. I love the EDFC, and when drag racing on slicks I can fine tune to my liking. Overal, these are better suited for my style of driving and power, they understeer at the limit slightly, and for me thats perfect because oversteer is a 1/2 throttle away...with sway bars Im positive I can dial it neutral or even some oversteer but Im happy with the switch.
Old Oct 15, 2007 | 05:36 PM
Triple8Sol's Avatar
Triple8Sol
Love my Tein Flex w/EDFC. Great on the street, and have worked great in AutoX as well. Have yet to track on them...
Old Oct 15, 2007 | 05:39 PM
Triple8Sol's Avatar
Triple8Sol
So true...
Old Oct 15, 2007 | 08:45 PM
asianracerchick's Avatar
asianracerchick
Jic Flt-a2!!!
