How to break-in new springs?
Old Oct 22, 2007 | 09:08 PM
rickyislaZy's Avatar
rickyislaZy
Default How to break-in new springs?
Hello guys I just got some Hotchkis springs installed on Saturday, the car still looks like stock height for now.
I have until this Saturday or Sunday to go in for alignment, does anyone know how to make the springs settle all the way in a week?
Thanks.
Edit: Included pictures of what it looks like now.
Old Oct 22, 2007 | 09:11 PM
Sean's Avatar
Sean
fat chicks?
Old Oct 22, 2007 | 09:57 PM
350ZTheStandard's Avatar
350ZTheStandard
drive damn hard, push the Z hard.....don't hit any walls
repeat as necessary
Old Oct 23, 2007 | 12:19 AM
rkd350z's Avatar
rkd350z
drive like you just got set of springs..
Old Oct 23, 2007 | 03:14 AM
Z04's Avatar
Z04
normal driving will settle your springs just fine
Old Oct 23, 2007 | 10:37 AM
stu8319's Avatar
stu8319
I was under the assumption that good springs don't settle.
Old Oct 23, 2007 | 04:43 PM
Zivman's Avatar
Zivman
They don't. They will however seat. After a fresh install, the springs will need to seat in place as well as the rest of the suspsension will be relaxed and stretched. The springs will seat, not settle
Old Oct 23, 2007 | 05:59 PM
rickyislaZy
It has been 3 days, does my car look any lower than stock?
Old Oct 23, 2007 | 07:58 PM
!prjctmax!'s Avatar
!prjctmax!
You tell us?
Old Oct 23, 2007 | 08:09 PM
rickyislaZy
Originally Posted by !prjctmax!
You tell us?
I seriously can't tell, didn't take any before pictures.
Old Oct 24, 2007 | 03:43 PM
350ZTheStandard
In your mind does the car seem lower??? Cause without pictures only your mind can tell.
Rule 1. when doing any mod before & after pics, (are a must) plus hopefully pics of you doing the work are you only evidence....not counting the ideas in your mind that is.
Old Oct 24, 2007 | 03:51 PM
Delako's Avatar
Delako
I had new springs and such put in 2 months ago..and TODAY I looked at the car and said "Oh...it looks lower..cool". I was tryin to notice a difference in the first few weeks but didnt see any, probably because I was lookin too hard. It Was probably that way the whole time, but for some reason today was the day I really noticed.
Old Oct 24, 2007 | 04:19 PM
mzdfc3s's Avatar
mzdfc3s
i agree, at least a month or more. in fact, i drive 100 miles a day with the hotchkis and for the first month the drivers side was lower than the passenger cause i rarely have anybody with me......2-3 months later it looks great!
Old Oct 24, 2007 | 04:20 PM
Z1NONLY's Avatar
Z1NONLY
I noticed mine when I reached for the door handle. It was not where I was used to it being. I drove mine back and forth over speed bumps at low speeds. The springs seated after only a few passes.
Just to be sure, park it next to a stock Z. I went to the dealership and found an open spot next to a stock Z. This is about a 1" drop and I think you still have to look hard to see.
Old Oct 24, 2007 | 04:56 PM
350ZTheStandard
Did anybody have enough snap to measure your car at all 4 wheels, to get a baseline measurement on the setup???
If each corner of your Z is at a different ride height this would not be a smart or good thing....right????
If no (measuring all 4 corners of the Z before changing the springs & swapping out the sway bars)then how can you truly tell if your car is sitting lower or not??
Old Oct 24, 2007 | 05:53 PM
Z1NONLY's Avatar
Z1NONLY
I was fixing a visible fender-gap issue due to shorter tires. The RS-R springs made the fender-gap look stock again, as planned. The fact that I can't get my jack under the car, w/o driving the two front tires onto 3/4" MDF sheets, shows me the car is indeed lower than it was before the springs.
I also used horizontal lines in photo software to show that my Z is lower than the 07 stock Z's. (I already knew it was lower but this helped me quantify it.)
Old Oct 24, 2007 | 06:05 PM
350ZTheStandard
So did you physically measure all 4 corners to see what the ride heights are, are they the same on both front corners, also on both rear corners? By the pics I can see the Blue car is lower than the stock 07 Black Z model, just asking if the ride height is the same height. If not, how do you adjust the kit to even up the ride heights if necessary?
Also looking at the pics I see the 07 Black Z is not as low as your car??? The Daytona Blue Z is not a 07 model, see the hood tells us this, what are the original rides of the 2 different years of Z cars, also are they the same model ( base vs: track or enthusiast)???
Just want to compare apples to apples, & not apples to Heroin!!!!
Old Oct 24, 2007 | 06:37 PM
OffsetZ33's Avatar
OffsetZ33
Originally Posted by sean1967
fat chicks?
thats what I was going to reccommend
Old Oct 25, 2007 | 06:07 PM
Z1NONLY's Avatar
Z1NONLY
It wasn't even at all corners when I first put the springs on. After a few speed bumps, the fronts and rears looked good (and still do). I didn't measure the car, before and after, but I can't get my jack under the %$#*&@# car now and before it was no problem. So the car is lower for sure.
*edit* I just measured each corner from the bottom of the splashguard to the ground.
Driver front=3-3/8" Passenger front= 3-1/4"
Driver rear=6-1/2 passenger rear= 6-3/8"
Old Oct 26, 2007 | 05:43 AM
Le Zed's Avatar
Le Zed
+1 on the fat chicks!
