How to break-in new springs?
Fat chics & lots of gas are expensive solutions. You gotta keep feeding the fat chics & gas nowadays are approaching $3/gallon. Sandbags are better to break-in and lower your Z - pay for it once and it's low maintenance. Place a few in the back and a couple on the passenger floor and you're good to go.
On a more serious note, OP should have measured the height -- from the ground to the the highest part of the fender well lip. Both rears should be the same height. Front passenger side is almost always lower than the front driver side. After installing the mod, re-measure to see if it is lowered. Pictures will not provide you the detailed information you need to know if your Z is actually lower after the mod.
