Question for the suspension guys
Old Nov 4, 2007 | 09:28 PM
island03z's Avatar
island03z
Default Question for the suspension guys
First off, I have an 04 Z with stock suspension and I honestly have to say I love the way it drives and handles stock with the exception of body roll. I believe the car was designed to be driven, and so I drive it very hard 99% of the time. I've been through a bunch of track days up to HPDE 3 in NASA in a stock Z (with the exception of wheels and tires and brakes) so I know the limits and how the car handles and it is very predictable and I like that. It is my daily driver and I like the way it rides on the street. My question is, how do I get rid of the body roll without making too much of a sacrifice on the things I like about the stock suspension?
Old Nov 5, 2007 | 07:16 AM
Gsedan35's Avatar
Gsedan35
Since you have a 04, you may have one of two different oem suspension's that are rather different from one another. It would help for anyone to be able to give a accurate as possible reply to know which oem suspension you have. The easiest way I can think of is to simply ID either the front or rear shocks. Even though the replies may not change in the end, it's still a good thing to know because of differances in compression dampning, front sway bar strength and rear spring rate.
On your front shocks look for this label
or this label
On the rear shocks look for this label
If no shock has any of the label's shown in the pics above, you have the unrevised suspension.
Old Nov 5, 2007 | 08:10 AM
VIZAGE's Avatar
VIZAGE
Sounds to me like you would love the Hotchkis spring/sway kit? When I first had it, it felt just like stock without the body roll or more of a neutral feel anyways. But it also sounds like you don't want to lower your car. But I would recommend that you do. It will help overall and it's just a small drop. But at least get the adjustable sways and go from there. But would be cheaper if you bought the kit.
Old Nov 5, 2007 | 05:04 PM
island03z's Avatar
island03z
Ill check on that suspension upgrade thing tomorrow when I've got it up on stands.
I was thinking about sway bars but my friend with a mazda 3 got some new beefy ones and they are wonderful on the track but an absolute terror to go over one wheel bumps on the road with them. anyone have any complaints about the hotchkis's being too stiff? Im considering the stillen too now.
Old Jan 13, 2008 | 03:37 PM
island03z's Avatar
island03z
Turns out I had the updated suspension. I ended up going with RS*R springs and hotchkis sways and I LOVE the combination. It did exactly what I wanted to do still maintaining nice ride quality while reducing body roll. Wheel gap in the front is gone but the back still has a bit which I'll live with. I'm still in the process of tuning the sway bars. Right now I have it on the 80s setting for both bars and I'm getting a bit of understeer.
Old Jan 13, 2008 | 05:33 PM
terrasmak's Avatar
Back the front bar off a little, I made the same mistake when i installed mine. Use hole #1 in the rear and hole #2 in the front.
Old Jan 14, 2008 | 07:06 PM
island03z's Avatar
island03z
Cool, I'll try that. I might leave the front at 80 and put the rear at 125 and see what that does as well and choose between the two. I'll post pics of the drop and updates on the handling balance after the next track day.
Old Jan 14, 2008 | 07:12 PM
redmike_02's Avatar
redmike_02
Are you still running stock shocks?
Old Jan 14, 2008 | 07:21 PM
island03z's Avatar
island03z
yea still running stock shocks, its everything I was looking for. I may consider aftermarket shocks later but for now this works wonderfully.
Old Jan 14, 2008 | 09:12 PM
terrasmak's Avatar
I tried that too, it gets real tailhappy. Its just to still for the stock springs and shocks.
Old Jan 19, 2008 | 05:36 PM
Cheezwiz's Avatar
Cheezwiz
If his only concern is body roll and likes everything else about the suspension, wouldn't a stabilizer upgrade be the best solution?
Old Jan 20, 2008 | 01:08 PM
trodis's Avatar
trodis
Hotchkis TVS Kit FTMFW! You'll love it! I do!
Old Jan 20, 2008 | 01:31 PM
Z1NONLY's Avatar
Z1NONLY
Default Settings between the settings
I have the same combo. RS-R springs and Hotchkis sways. Here's what I did, and it has worked very well. (on and off the track)
https://my350z.com/forum/brakes-and-suspension/312887-sway-bar-settings-between-the-settings.html
Old Jan 20, 2008 | 01:38 PM
r_seng's Avatar
r_seng
Swift SpecR springs
Tokico Dspec shocks
Hotchkis sway bars
Old Jan 20, 2008 | 08:02 PM
island03z's Avatar
island03z
What size tires are you running? I'm still getting a little more understeer than I'd like with the setting u suggested. I'll try going the other way although some people have said it brings about a snap oversteer effect.
https://my350z.com/forum/showthread.php?t=312887
Problem is I'm running a 245 in the front and 275 in the rear so im getting understeer where I don't want it.
Old Jan 21, 2008 | 02:51 AM
Z1NONLY's Avatar
Z1NONLY
That's almost identical to my 255 / 275 setup.
Old Jan 21, 2008 | 10:45 AM
island03z's Avatar
island03z
what tires are you running?
Old Jan 21, 2008 | 01:14 PM
Z1NONLY's Avatar
Z1NONLY
Up until a couple months ago, Kumho MX's. Now I am running Falken Azenis 615's. (-Couldn’t find the Kumho's in my sizes this time) There are some differences in the tires, but my car's overall balance is unchanged by the tire swap.
Old Jan 24, 2008 | 08:25 PM
island03z's Avatar
island03z
cool, its been snowing here so i havent had a chance to switch out the stiffness. I'll try that one hole thing you mentioned. Hochkis said it was perfectly fine for those who are wondering if it will mess anything up.
Old Jan 31, 2008 | 06:55 AM
island03z's Avatar
island03z
So I got around to switching out only one hole on the front. I like the handling but the body roll is back so I'm back to square one. I will try doing only one hole in the back and see how that feels.
