Front Coilover Height Adjustment Problem - Advice Needed Please
Old Nov 10, 2007 | 02:37 AM
DMK's Avatar
DMK
Default Front Coilover Height Adjustment Problem - Advice Needed Please
Ok, so I set the height of the front coils to where I would want them and started putting everything back together. But I am having a problem reconnecting the end link. The lower arm where the bottom of the shock is connected to is now higher since I shortened the damper length to make my car a bit lower. When I go and try to reinstall my endlinks, I can't get them to line up with any of the sway bar holes. The endlink is now too long. Is this a common problem? Am I doing something wrong?
Old Nov 10, 2007 | 05:52 AM
abui01's Avatar
abui01
Never heard of this problem... why don't you try jacking the car back up and take the load off the suspension to a point where you can reconnect back the end link. Either that or SPC sells adjustable end-links where you can adjust its pre-load/height
Old Nov 10, 2007 | 09:21 AM
DMK's Avatar
DMK
In that picture, the car is already jacked up. I just put the vertical arm the rotor/brake is connected to into the a-arm to make it straight. Even if I take off the a-arm and move the vertical arm left, right, up or down it won't line up with the holes. If I put the endlinks on first, then the lower arm sits too low for me to attack the shock to the lower arm.
Old Nov 10, 2007 | 07:24 PM
terrasmak's Avatar
Is the other side of the car still on the ground??? . Are thecoilovers both set equally.
Old Nov 10, 2007 | 08:50 PM
DMK's Avatar
DMK
Both sides were in the air. I basically ended up putting in the endlink first and then using a jack to jack up the lower arm, so that I could attach the coilover. The endlink is under stress, but it seems to be holding up. I was just afraid of it snapping as I jacked up the lower arm.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Vigman
Nov 17, 2015 04:34 AM
codek
Sep 27, 2015 03:21 PM
