Install Springs & Rear Camber / toe bolt?
Old Nov 10, 2007 | 09:29 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Question Install Springs & Rear Camber / toe bolt?
Hi, guys.
i've looking for shop to put these on for my 04 Z
but shop asking me 300+ for install fee.
me and my friend decide, we try install our self
i've searched tech area
but ihaven't find any good answer,
anyone has experince ? or has pictures with?
Please HeLp~!!
Old Nov 10, 2007 | 10:59 PM
Gsedan35's Avatar
Gsedan35
Jack rear up use two jack stands on the diff.
Remove tires
Unbolt shocks at the lower mount and push them off the lower mount.
Place floor jack under lower control arm where spring sits, you will support control arm enough to free bolt close to the brake rotor side, goal is to remove bolt attaching lower control arm to hub. With bolt out, work the lower control arm off hub, lowering jack carefully while you do this.
loosen the inner bolt on the control arm that is closest to the center of the car, lower control arm til you are able to remove the spring.
Repeat other side.
Use the link below to install elongated SPC toe cam bolts
https://my350z.com/forum/brakes-and-suspension-diy/185737-spc-toe-bolt-install-write-up-with-pics-courtesy-of-protocav.html
Old Nov 11, 2007 | 07:35 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
wow not easy, thanks !!!
seagrasser
Oct 11, 2015 03:27 PM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
