Dropping with GF210
Old Dec 6, 2007 | 04:57 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I can't say how the Tokico blues are, I dont think we've ever used them. I only recall using the D Spec adjustables, and given their low price, that's what I'd use
Old Dec 6, 2007 | 06:00 AM
Nukiz0r's Avatar
Nukiz0r
How about my question on the camber kit? With the 210s, you think I only need the rear kit? I think the rear is the one that gave the tech the most difficulty getting aligned. I wish I could afford the D-specs, but again, on a strict budget.
Old Dec 6, 2007 | 06:04 AM
Z1 Performance
Former Sponsor
No one can tell you if you will absolutely need it or not, as it depends on many factors, including the current alignment specs of your car, tire size/offset, etc.
From the factory the only thing you can adjust is front toe. Rear toe is slighly adjustable (not even 1/2 degree). So having an adjustable front kit and a rear adjustable camber/toe kit would be a tremendous benefit to any Z, not only lowered ones, as it will allow the tech to actually give a real alignment to the car, which leads to better overall handling and better tire wear
Old Dec 6, 2007 | 06:14 AM
Nukiz0r's Avatar
Nukiz0r
Thanks Adam, when I get back home in a month I'll post the information and ask for advice. Since the Z is garaged for the winter I have little fear of wearing out the tires until I get what is needed for it.
Old Dec 6, 2007 | 07:25 AM
Z1 Performance
Former Sponsor
sounds good - if you want, email it over to me and from there we can help you figure out what you do/don't need
Old Jan 13, 2008 | 11:03 PM
WyattH's Avatar
WyattH
Sorry to resurrect this thread:
With the Tanabe GF210 drop (1F/1,2R), I understand that rear camber/toe kits are required (SPC, Kinetix, etc) style for under $200...
What about the front? I understand the Z does not come with much in terms of adjustable parts, so upon alignment, can they change anything in the front or get it back to stock specs? Or will they be out of wack anyway after the drop?
Thanks.
Old Jan 14, 2008 | 05:54 AM
Z1 Performance
Former Sponsor
post #23 of this thread
no one can tell you if you will or will not need a front kit - every car is different, every car reacts differently to lowering. The only way to know is to check the specs after install and see where you ended up, or, take the preventative route and get the front a arms as well, so you only have to go into get the alignment 1 time instead of making multiple trips after install
Old Jan 14, 2008 | 07:10 AM
Nukiz0r's Avatar
Nukiz0r
Adam, Im going to post my info shortly. Glad you resurrected this thread, so I didnt have to look for it. =)
Old Jan 14, 2008 | 07:19 AM
crg914's Avatar
crg914
Adam,
I sent you an email with some questions about suspension and never got a reply. Can you help me out, I am in the market.
Thanks
Old Jan 14, 2008 | 07:42 AM
Z1 Performance
Former Sponsor
sorry I dont have any message from you
Old Jan 14, 2008 | 11:30 AM
WyattH's Avatar
WyattH
Reading comprehension owns me. Sorry about that, thanks for the info.
I'll look around now, but is the front a-Arm or camber kit approx the same price as the rear? Do they both allow for full adjustment of camber/caster/toe, etc?
Old Jan 14, 2008 | 11:46 AM
marques1's Avatar
marques1
WyattH the fronts are more expensive then the rear camber kit. If you have the 210 lowering springs you should be okay with just the rear camber kit. The front should come in alignment just fine on MOST car depending on your setup you have.
Old Jan 14, 2008 | 12:03 PM
ALO8's Avatar
ALO8
i installed the gf210's with rear spc rear camber. I went for an alignment and was told the rears were perfect but the front was off, plus they said my front bushings were torn because lowering the z put alot of stress on the stock bushings. i dont know how to read the specs of the front but ill post them later.
Old Jan 14, 2008 | 01:13 PM
WyattH's Avatar
WyattH
Oh man, so much conflicting information..
A forum vendor just said $500 shipped for SPC front a-arms and full rear camber kit... I might just do that to be safe. Rear is just $160 or so Ughhh. Hoping torn bushings aren't common.
Old Jan 14, 2008 | 04:43 PM
crg914's Avatar
crg914
Just sent you the same PM. Check and see if you can help.
Thanks in advance.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
