Inside tire wear with Hotchkis TVS
Old Nov 24, 2007 | 05:50 PM
TheProfessional's Avatar
TheProfessional
Default Inside tire wear with Hotchkis TVS
I installed a set of BFG KDW2 OE size on my 2006 last November. I run 34-35 psi year round.
I noticed this week I had very low tread depth on my right rear and changed it out. What I noticed was 1/32" tread in the middle of the tire, 2/32" on the inside of the tire, and 5/32" on the outside.
Is this proper tire wear??
This is a new BFG KDW2:
This is the old tire after 20,000 miles mostly on the Hotchkis TVS:
This is the wear in the middle:
This is the wear on the inside of the tire:
This is the wear on the outside of the tire, a significant amount more than the inside:
This is the side view of the offending wheel:
Another side view from the other side:
This is the drop on the back:
Old Nov 24, 2007 | 06:04 PM
Zridder19's Avatar
Zridder19
Did you get an alignment after you dropped it?? I know that stock camber is ok for 1 to 2 degrees neg. either way will wear a bit on your tires.
Old Nov 24, 2007 | 06:08 PM
TheProfessional
What's alignment?
No j/k. Actually the drop has progressed SLOWLY from almost no drop initially to what you see and it appears to have crept up on me. I have not noticed any alignment problems, perhaps it is time, but I am putting off until I get new wheels/tires.
EDIT: Oh did I mention, this tire has 30% less tread than the rest of the tires.
Old Nov 24, 2007 | 06:12 PM
No. 1/32 and 5/32 is a considerable difference.
Old Nov 24, 2007 | 06:15 PM
VIZAGE's Avatar
VIZAGE
I would say that's about proper wear for your setup. You could have a little more even with a rear camber kit. But even with the better tread depth on the outside, it would still be time to change tire anyways. And if that tire has less than the others, toe needs to be check. Which all of it's done at the same time anyways.Go ahead and plan on a rear camber and toe bolts. Very cheap compared to tires.
I have to say that Hotchkis kit looks like it really settled more than others. Mine I used to have were no where near that low. But my Eibach pro-kit is about that (one finger when on perfect level ground).
Old Nov 24, 2007 | 06:18 PM
TheProfessional
I thought it was a bit more than normal, I wonder if I will start rubbing one day with stock wheels/tires on a hotchkis! LOL j/k
A couple of people at Zdayz asked what springs I had and seemed surprised it was Hotchkis... again I thought it dropped the back more than the front...
Old Nov 24, 2007 | 08:04 PM
rickyislaZy's Avatar
rickyislaZy
Hey dude, got any profile shots of your car?
I hope my Hotchkis can go lower.
Old Nov 24, 2007 | 10:46 PM
TheProfessional
The tires were installed 12/08/06, the Hotchkis kit was installed 2/11/07. This photo was taken 4/19/07. I dont have any more recent pics:
Old Nov 25, 2007 | 06:10 AM
IIQuickSilverII's Avatar
IIQuickSilverII
What's alignment?
ok redo the alignament after your new wheels and tires and come back to the thread in 1 month...
cause if you drop your car you have to get it aligned, its natural that the camber will start to get gradually off...doesnt mean your stearing will go off completly ..lets say, to the right...you might not feel it since we are talking 1%s....
Old Nov 25, 2007 | 01:46 PM
Sean's Avatar
Sean
your tires are angled in do to the drop, the inner part of your tire is hugging the road hard while your outter rubber barely makes contact. Soon the ply will split while you are driving.
get a kit with a camber and toe arm. these guys put out a nice product at a great price, don't overpay just to have a brand name on your bolts.
http://stores.ebay.com/Speed-Racer-P...QQftidZ2QQtZkm
Old Nov 25, 2007 | 01:59 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I read that with Hotchkis TVS Stage 1 kit, you didn't need a camber kit. Getting an alignment should fix the negative camber caused by the drop from the hotchkis springs, right? No need for any additional modifications to the suspension to get everything back to spec?
Old Nov 25, 2007 | 02:28 PM
TheProfessional
That's what I'm trying to figure out. Also, thinking of moving the rear OEM tire fitment 245/45/18 to the front where I already have 225/45/18 and then putting 275/40/18 on the rear, so some negative camber MIGHT be good.
Old Nov 25, 2007 | 03:09 PM
VIZAGE's Avatar
VIZAGE
Yes, I thought the same thing also. But still needed them to get camber to my likings and in spec. But all cars act different to a certain point. Plus his springs seem to be a lot lower than Hotchkis is know for, even over time I don't think they should settle that much. But looks good. So I feel he's running more camber than can be corrected. But I can be easily wrong.
I think it would be in best interest to buy a $135 kit and have a alignment done once after the new tires.
Old Nov 25, 2007 | 03:25 PM
3hree5ive0ero
Retired Admin
245/45/18 is too tall for the front. The optimum size, if going with 18 inch rims and 245 mm width, is 245/40/18. Your speedometer, odometer, mpg, etc will all be off. Also, in what settings would negative camber be good?
http://www.1010tires.com/TireSizeCalculator.asp
^ Use that to calculate the best tire size and see how much things are affected.
If I were to get new tires and get the alignment redone, they'd tell me if I need a camber kit or not, right?
I'm assuming that if they can't get it into original spec, then they'll get it as close as possible and tell me that it's not in spec, at the very least.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
