Tein Flex not low enough at the back
Old Dec 2, 2007 | 09:29 AM
Colin_S's Avatar
Colin_S
Default Tein Flex not low enough at the back
I've dropped my Z on a set of tein flex but the back doesn't go low enough. Anyone know of other spings i could use that would allow me to drop it further?
Thanks
Old Dec 2, 2007 | 09:30 AM
myladyz33's Avatar
myladyz33
im guessing you mean s-techs and i had the same problem
Old Dec 2, 2007 | 11:19 AM
NOBI's Avatar
NOBI
bricks in the back usually work.... adjust the coilover so that it is lower???
Old Dec 2, 2007 | 03:21 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Cut the rear rubber mount some. You can shave off 1/2" safely
Old Dec 2, 2007 | 03:49 PM
Zilvia's Avatar
Zilvia
coil overs
Old Dec 2, 2007 | 05:44 PM
cheshirecat79's Avatar
cheshirecat79
yep. do this. its easy and its free.
Old Dec 2, 2007 | 08:34 PM
Moroccan_Mole's Avatar
Moroccan_Mole
you can also run without the rubber mount
Old Dec 2, 2007 | 09:51 PM
TimeAttkZ's Avatar
TimeAttkZ
Originally Posted by Zilvia
coil overs
Dude... the Tein Flex are coilovers !
Old Dec 2, 2007 | 09:56 PM
Zilvia's Avatar
Zilvia
are they not adjustable
slam it then
Old Dec 2, 2007 | 10:01 PM
black06z's Avatar
black06z
Either cut the rear spring mount, or get some other coilovers like Stance.
Old Dec 3, 2007 | 12:40 AM
Colin_S's Avatar
Colin_S
Yea i've got coilovers and they are at the lowest setting at the back but not low enough. The front is balanced and only adjusted about 2/3s of the way down.
What i was wondering is can i get a couple of spings for the back to replace the ones that came with my kit so i can lower the car more?
Old Dec 3, 2007 | 01:34 AM
tanman8181's Avatar
tanman8181
remove a collar
Old Dec 3, 2007 | 01:53 AM
blazed54's Avatar
blazed54
i thought the rear was supposed to be higher that way when you accelerate and the rear squats, your car doesn't look like a boat in water?
Old Dec 3, 2007 | 06:07 PM
terrasmak's Avatar
Order a set that are an inch shorter http://www.tein.com/products/standar...rice_list.html i'll bet if you called tien , you wouldnt even have to measure anything.
Old Dec 4, 2007 | 02:05 AM
Colin_S's Avatar
Colin_S
Supperb, exactly what i wanted. I'll do that.
Thanks
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
