Problem with SPC rear camber kit. need help
I recently put on my SPC rear camber and toe bolt. I sloted out the holes per directions and lowered my car about a inch, perhaps slightly more in the rear. I installed them well, but I heard that there was a strange but loud clicking noise from rear suspension whenever I launch at 1st gear. I jerked the car intentionally to see if the noise continues, and it is getting worse everyday. I didn't have any noise until I install SPC camber kit. In addition, I did alignment. Has anyone had problems with their SPC camber?
I've had no problems. But your going to have to get under there to check for any loose parts. Camber arms, bolts to them, toe bolts, sway bar (might need to be greased), endlinks and anything else connecting to the suspension componets. You said clicking and not rattling, but check for exhaust rubbing somewhere to be sure. Might want to have alignment checked again?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
