e-brake
Old Jan 8, 2008 | 04:26 PM
2boosted4u's Avatar
2boosted4u
Default e-brake
i cant find any DIY adjustments on the emergency break...does anyone know if there is one out there?
Old Jan 8, 2008 | 04:29 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
there are 2 ways one is pull your rear brakes off and adj. the small drum brakes in the back. and another is pull out your center console and there is a 10mm nut with a stud through it that you can tighten to make it work gooder.
Old Jan 8, 2008 | 04:32 PM
rhynesimpson's Avatar
rhynesimpson
All i have to say is *brake.
Old Jan 8, 2008 | 04:34 PM
Hoods's Avatar
Hoods
Good looks, mine is pretty weak. Barely works, if at all, if I'm on any type of angle. Granted I just need to throw the car in gear but still annoying.
Old Jan 8, 2008 | 04:44 PM
2boosted4u's Avatar
2boosted4u
i have a 2003 track with the brembos is the adjustment the same on the breaks still?? are there any how to or DIY with pixout there?? or do i have to be the breve one?
Old Jan 8, 2008 | 05:34 PM
gothchick's Avatar
gothchick
+1. I adjusted mine under the center console when I was having my stereo put in.
Old Jan 8, 2008 | 05:43 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
thats one way but you will run out of adjustment there eventually you really need to pull off you rear brake rotor and there will be a small "star wheel adjuster" at the bottom of the e brake assembly all you do is turn it to push the pads out and put there rotor and adjust it till it just bairly clears the rotor and spins free.
Old Jan 8, 2008 | 06:01 PM
ke0ki2k's Avatar
ke0ki2k
"Cheese eating surrender monkeys" FTL
^- france?
Old Jan 8, 2008 | 06:57 PM
2boosted4u's Avatar
2boosted4u
i think ill do both cause im catchs wayyyy to high and i want it to catch quick for drifting in the wet instead of poping my clutch
Old Jan 10, 2008 | 09:04 AM
2boosted4u's Avatar
2boosted4u
has n e one done this and made a DIY??
Old Jan 10, 2008 | 09:24 AM
moog's Avatar
moog
I've taken my ebrake off, when I had to replace the hub in the rear. It's really not that hard. If you just want to reach the star adjusting screw take off your wheel, take off your brake caliper, take off the rotor. The adjuster will be exposed and you just turn it w/ your finger.
Old Jan 10, 2008 | 03:33 PM
2boosted4u's Avatar
2boosted4u
works for me ill do it when i have my rims painted thanks
first350
Drift
24
Sep 8, 2007 08:10 AM
s31t8n8
Apr 5, 2007 05:16 PM
Cyase
Drift
May 31, 2003 02:45 PM
