Hotchkis $$$ ?
Old Jan 12, 2008 | 05:58 AM
350acid's Avatar
350acid
Default Hotchkis $$$ ?
How much did you pay for instalation hotchkis springs?
Local shopin Tempe AZ. wanted 400$ (315+85 alignment)
Old Jan 12, 2008 | 05:59 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
seems a bit high...
DIY FTW
Old Jan 12, 2008 | 07:29 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Tanabe GF210 + Rear SPC camber/toe + align($80)
around 350
ONLY Springs install can't b that much
shop told me put TOE is more job then put springs on
Old Jan 12, 2008 | 08:29 AM
trodis's Avatar
trodis
i just had mine installed yesterday (springs and sways), cost 500 with alignment and now i need a front camber kit, so look into that as well.
The car feels amazing after the install well worth it!
Old Jan 12, 2008 | 09:49 AM
Zivman's Avatar
Zivman
doubt you need a front camber kit. if you are under -1.75 you should be fine. Being slightly out of OEM spec isn't bad. On my hotchkis I was right around -1.4 degrees, which is where I would guess you are... definitely not worth getting front camber arms for
Old Jan 12, 2008 | 09:51 AM
Zivman's Avatar
Zivman
That is ballpark.... I would think the install could be done in 2 hrs for a shop. So figure what shop rate is at 2 hrs + the cost of the alignment
Old Jan 12, 2008 | 10:04 AM
cdoxp800's Avatar
cdoxp800
I paid $90.00 at a local auto shop
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
deviant1
Nov 29, 2004 11:26 AM
Leh GSC
Sep 14, 2004 05:15 PM
Anishd
Jul 30, 2004 06:49 AM
