To those that have installed their own BBK
Old Jan 17, 2008 | 05:33 AM
chris'smax's Avatar
chris'smax
Default To those that have installed their own BBK
When installing your kits did any of you use any kind of thread lock on the mounting points of the caliper or brackets? I have the project mu kit which I installed and it came with washers for all the bolts. I have had the kit installed for about a month now with now problems but was just curious to see if some of you were taking this route.
Thanks
Old Jan 17, 2008 | 05:49 AM
TruBluZ's Avatar
TruBluZ
I didn't use thread lock and have had zero problems with mine.
Old Jan 17, 2008 | 06:45 AM
VO...'s Avatar
VO...
Administrator
The Stop Tech kit requires thread lock on the caliper brackets. I use it. I personally don't believe thread lock serves any real purpose on bolts that are going to be torqued down with ungodly force to begin with. If anything, it's redundancy. Now on smaller delicate bolts that are torqued down with inch lbs, that's a different story. I've had cases where they vibrate loose because thread lock was not used.
-2 cents-
Old Jan 17, 2008 | 07:37 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
On bolts that do not use a lock washer, we include thread lock. Most factory applications use either a lock washer or thread locker on their caliper mounting bolts and we maintain those methods when we develop kits.
Old Jan 17, 2008 | 08:50 AM
chris'smax's Avatar
chris'smax
im not sure what the technical name for the washers were, but the look like a standard washer with grooves in the surface of it to help bite into the matting surface. It wasn't a conventional lock washer.
Old Jan 17, 2008 | 09:24 AM
DustinZ33's Avatar
DustinZ33
You're probably talking about a serrated belleville or wedgelock washer.
Old Jan 17, 2008 | 10:49 AM
SpoilsofWar's Avatar
SpoilsofWar
No thread lock on my AP Racing kit, dont believe there was lock washers used either, but its been a while since I did it.
Old Jan 17, 2008 | 12:03 PM
350ZTheStandard's Avatar
350ZTheStandard
+1
Lock Tite not necessary, & the washers are called crush washers, least that was what my local stealership calls em .52 cents each
Old Jan 17, 2008 | 12:51 PM
moog's Avatar
moog
Didn't use thread locker on my GREX kit. Had them on for a good 15-20k miles, and i took the caliper off this past weekend to check the brake pads. The bolts were still waaaaaaay tight, so I'm not worried about it.
Old Jan 17, 2008 | 01:01 PM
dklau33's Avatar
dklau33
I just followed what the Stoptech instructions said and used the supplied Loctite.
Old Jan 25, 2008 | 09:48 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
loctite is cheap insurance, especially for track goers. it's hard to imagine just what can shake loose when your car is at 5-7k RPM, turning left and right and going in whatever direction all day.
