Braces Material
Old Jan 17, 2008 | 10:32 AM
kaminariZ's Avatar
kaminariZ
Default Braces Material
Hey guys, i wanted to know if any of the braces could be made out of stainless steel square tubing, instaed of aluminum. I ask this, because I can weld steel, but i don't have teh tools to weld aluminum. And what i want to do is make all the braces for my Z, such as fender braces, lateral braces, tie braces, etc. And for my other car as well. And itwould be much more cost efficient. What are the downsides of using stainless steel other than weight issues. Thanks.
Old Jan 17, 2008 | 10:42 AM
SpoilsofWar's Avatar
SpoilsofWar
Theres really no reason you couldn't make them out of steel, although like you mentioned they will be much heavier.
Some of the bends may be harder to reproduce also.
Old Jan 17, 2008 | 10:49 AM
VIZAGE's Avatar
VIZAGE
I can only think of weight issues. Not sure if aluminum gives more, like it would need to flex a little under pressure. But that would defeat the purpose. Unless it is ment to give some for our cars.
Are you planning on making the bar type that will be hollow or just thinner solid bars?
Old Jan 17, 2008 | 10:51 AM
06blueZ's Avatar
06blueZ
Cro-moly's strength to weight ratio is greater than aluminum...
Old Jan 17, 2008 | 10:55 AM
kaminariZ's Avatar
kaminariZ
awesome. than i will be building all my braces out of stainless steel tubing. a decent gauge, thats not too heavy either.
Justin100
Nov 29, 2015 03:58 PM
Mikey3288
Mid-Atlantic Marketplace
Oct 23, 2015 07:41 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
waldo36
Sep 20, 2015 09:13 PM
