SPL rear mid-link review and install
Old Jan 25, 2008 | 11:28 AM
RedBullRR's Avatar
RedBullRR
Love how slammed your car is. Def look sick!
Old Jan 25, 2008 | 10:40 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by kuah@splparts.com
Tony is using the dampers from his Stance coilovers, with the springs removed. There should be no difference in the performance of the dampers, as the motion/velocities seen at the shock should be similar regardless whether the spring is mounted on the damper or at the mid link (with equivalent spring rates given the motion ratio difference).
Interesting to see your conversion calculator, looks like you've measured the rear motion rate at around .776.
http://www.splparts.com/main3/Parts/...Calculator.xls
465lbs X .776 X .776 = 280lbs
Old Jan 28, 2008 | 06:39 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
The motion ratio is approx. 0.6. I made a mistake in not squaring the motion ratio when calculating the effective spring rates. The Stance and Buddy club coilovers should have an effective rate of slightly less (due to mounting angle) than 13.5kg/mm at the stock location.
Old Jan 28, 2008 | 07:58 AM
gothchick's Avatar
gothchick
Wow, thanks for the great review & pics! :-)
Old Jan 28, 2008 | 05:26 PM
thinking's Avatar
thinking
FYI, he indicates a similar calculation of .61
Originally Posted by Q45tech
I measured the FRONT lower arm length @14" and the spring closest point [length along arm from frame] @11" this results in a spring to wheel correction of 0.61 so a spring speced at 300 pounds per inch would really expert 300 x 0.61= 183 pounds per wheel inch. If you jacked up the wheel by 1" it would require 183 more pounds than static...........discounting sway bars this means the front roll rate stiffness is ~~183 lbs per inch.
So a 20% stiffer spring only truely increases FRONT roll stiffness by 20 x 0.61 or 12.2%.
Worse add in the sway bar and a 20% stiffer spring may only add 1/2 -3/4 so 6-9%.
Old Jan 30, 2008 | 09:51 AM
Gsedan35's Avatar
Gsedan35
He's talking about the front, not the rear. I trust Hippie's numbers more anyhow.
Old Mar 13, 2008 | 12:07 PM
RKnight's Avatar
RKnight
Twenzel what spring lenth and rate did you use? I am planning to use a softer 6 kg/mm 7" Swift spring to replace the 5.9 kg/mm Hotchkis spring in the rear.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
