GT Spec bar.
Old Jan 26, 2008 | 06:55 PM
acg's Avatar
acg
Default GT Spec bar.
I have a real quick question, will the front GT Spec front tie brace bar fit over an APS oil pan. I am not sure how much lower the APS oil pan sits compared to a stock one.
Old Jan 26, 2008 | 07:13 PM
Mike Wazowski's Avatar
Mike Wazowski
Im pretty sure it will not fit with any of the after market oil pans or spacers.
Old Jan 26, 2008 | 07:34 PM
acg's Avatar
acg
Thanks that's what I thought. I suppose there is no harm going back to the stock oil pan...lol
Old Jan 26, 2008 | 07:41 PM
Mike Wazowski
if you need higher capacity, you can install an oil cooler.
Old Jan 26, 2008 | 07:50 PM
acg's Avatar
acg
I have an oil cooler, I just thought it was necc. to have the extra quart when going FI. Plus it came with the APS kit.
Old Jan 26, 2008 | 07:53 PM
Mike Wazowski
the oil cooler should be giving you the extra quart, you could also add an Amsoil bypass oil filter system and up it by even more.
http://www.amsoil.com/storefront/bf.aspx
Old Jan 26, 2008 | 08:07 PM
acg's Avatar
acg
Thanks for the info, in that case I just need to buy a stock oil pan as well
Old Jan 27, 2008 | 05:31 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the new version that clears bigger pans will coming out in a couple of months
Old Jan 27, 2008 | 10:24 AM
SpoilsofWar's Avatar
SpoilsofWar
The old (current) version will fit with the GReddy pan. That is the only increased capacity pan or spacer that it will work with.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
