Broken Caliper Bolt
Old Feb 3, 2008 | 01:38 PM
Manifest's Avatar
Manifest
Default Broken Caliper Bolt
Hey guys -
While trying to remove my caliper, to replace the brake pads, I also broke the bolt that attaches the caliper to the rotor... It was extremely tough to get off, but after some work I thought I had succeeded... Came to find out I broke the bolt.
Does anybody know where I can get a replacement? Would the dealership have one to purchase?? Should i just abandon all efforts for trying to replace my own pads and just take the car to the dealership? How safe is it to drive with the caliper not firmly attached?
Old Feb 4, 2008 | 12:20 AM
Michla22's Avatar
Michla22
I wouldn't drive the car without both bolts holding the caliper into place. And yes you can order them from the dealership - should take them a couple of days to get them - also get some grease for the new bolt.
Old Feb 4, 2008 | 12:49 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
stealership is your best bet...which brakes?? brembos??
Old Feb 4, 2008 | 06:38 AM
Manifest's Avatar
Manifest
Naw - they're just stock calipers. Looks like the dealership might have a few bolts in stock... guess I'll pick one up tonight. Any advice on how to loosen up the remaining bolts without chopping them in half? I had to resort to putting the wrench about it, then wacking the wrench with a hammer. Even that didn't seem to loosen it up until the bolt broke in half.
Old Feb 4, 2008 | 06:46 AM
ev0k1ll3r's Avatar
ev0k1ll3r
wd40 and let it soak for a bit
Old Feb 4, 2008 | 07:28 AM
SuperBlack350z's Avatar
SuperBlack350z
use penatrating oil and let it sit for 5 minutes. They were easy to take off my car.
Old Feb 4, 2008 | 06:55 PM
Manifest's Avatar
Manifest
Thanks for all the help guys - I used the penetrating oil like was recommended, and got the replacement bolt. Everything came off lickity split. It was a good learning experience, especially for the next time I have to do it.
Appreciate all the help from you guys!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
