HKS HiperMax III --- FINALLY!!
Old Feb 13, 2008 | 07:44 AM
Chops@MVP's Avatar
Chops@MVP
Default HKS HiperMax III --- FINALLY!!
I have good news and great news! HKS HiperMax III's will be officially released VERY VERY SOON. I also have good word that the pricing on the 350z/G35 will be $1995 retail, putting them at a very good selling price of $1715.70.
The first 10 people that pre-order will receive a $50 gift certificate to MVP to be used on anything you want.
I can not say yet exactly what day they will be released, but I can tell you that if you pre-order now you will get a set from the first shipment to MVP and that it will make a very nice Valentine's Day gift for your loved one on 4 wheels.
Spring Rates: 9k front and rear
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
As we sell the first 10 sets I will list here in the first post how many sets are still available with the $50 MVP Gift Certificate.
Call in or email me to reserve your set along with your $50 MVP Gift Certificate.
If anyone has any questions let me know!
Thanks,
Robert
Old Feb 13, 2008 | 08:21 AM
Zexy's Avatar
Zexy
Will HKS ever release the Drag coilovers for the Z??
Old Feb 13, 2008 | 08:51 AM
Endless Shock's Avatar
Endless Shock
After reading your post, do these come with hard rubber mounts? Are the pillow ball mounts the extra option?
Old Feb 13, 2008 | 09:04 AM
Chops@MVP's Avatar
Chops@MVP
The drag coilovers will not be brought back for the III series.
Endless:
Hard upper mounts are standard on the street version(price listed) but may be an option for 350Z at a later date. Japan already has this option but HKS USA is telling me that they don't know if/when it will come to US that way. The sport model will come standard with pillowball upper mounts though.
Robert
Old Feb 13, 2008 | 09:22 AM
Zridder19's Avatar
Zridder19
secks
Old Feb 13, 2008 | 10:36 AM
rkd350z's Avatar
rkd350z
true coilover design like stance?
Old Feb 13, 2008 | 11:21 AM
Chops@MVP's Avatar
Chops@MVP
It is a true coilover per HKS.
Robert
Old Feb 13, 2008 | 09:13 PM
Gsedan35's Avatar
Gsedan35
I have collected specs that differ in some areas from what you show.
HKS Hypermax III 9/10 (part number 80140-AN009)
Digressive piston design
Hard rubber upper mount
Full height adjustablity seperate from spring preload
HKS Hypermax III Sport 11/12 (part number 80155-AN009)
Looks like it uses linear valving vs digressive
Pillowball upper mounts (HKS call's them 'Pyro" mounts)
Old Feb 13, 2008 | 09:22 PM
Pokémon's Avatar
Pokémon
Tempting~~
Old Feb 13, 2008 | 09:25 PM
TimeAttkZ's Avatar
TimeAttkZ
DAM THESE LOOK BADA$$ ! Very tempting...
Old Feb 13, 2008 | 09:38 PM
Cloud's Avatar
Cloud
the hipermax III do not have seperate shocks & springs?
Old Feb 14, 2008 | 11:26 AM
rkd350z's Avatar
rkd350z
true coilover style like stance
Chops@MVP's Avatar
Chops@MVP
It is not like your OEM suspension in the rear. It's all 1 peice.
Robert
Old Feb 14, 2008 | 11:29 AM
Chops@MVP's Avatar
Chops@MVP
FYI you can also use the $50 gift certificate towards the purchase of the coilovers
Robert
Old Feb 14, 2008 | 12:09 PM
mdracer76's Avatar
mdracer76
Robert
so are you going to sell an arm to replace the spring cup arm, or will that piece stay in place?
Old Feb 14, 2008 | 01:42 PM
ke0ki2k's Avatar
ke0ki2k
btw, MVP do you have the new GR+ coils with the revised 12kg/11kg spring rates?
Old Feb 15, 2008 | 06:33 AM
Gsedan35's Avatar
Gsedan35
Robert
Then none of the spring rates are correct..
Published spring rate data at HKS Japan makes it all but impossible that the
Z33 setups are truecoilovers in the rear.
While polite, I've never been impressed with whoever gives out info at HKS USA.
Old Feb 15, 2008 | 06:42 AM
ATL_Red_G35's Avatar
ATL_Red_G35
how reliable are true coilover setup on our car. I love them, but don't know if our car is made for that.
Old Feb 15, 2008 | 06:44 AM
asianracerchick's Avatar
asianracerchick
me liiikee!
Old Feb 15, 2008 | 06:57 AM
Marty_G's Avatar
Marty_G
wow.. bada$$ coils
