noob help, lowering my Z!
Old Feb 23, 2008 | 07:39 AM
just_another_z's Avatar
just_another_z
Default noob help, lowering my Z!
ok i recently bought a 04 ppw 350z,but before this i had 2 trans ams and 1 camaro,i must say, i feel like i moved way up in the world after i started driving my Z!
now my question is this, i have 18's on the car and its still at stock height,i want to lower the car 2 inches, but before i do i need some professionals opinions (you). is 2 inches too much for the car and by too much i mean is it gonna be hard on the car, im not worried about a rough ride for me or anything like that because all my cars have been dropped. any help is appreciated, i am a noob to the Z world so i can use any extra advice!
Old Feb 23, 2008 | 07:49 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The search button is your friend.
Old Feb 23, 2008 | 07:50 AM
Fletch69z's Avatar
Fletch69z
I went with Tanabe GF210's and they dropped my Z about 1 1/4" which seems to be about perfect as far as not rubbing the bottom of the car (too much) and not rubbing the fender wells, which are pretty close. If you went with that much drop you would also need a camber kit.
Old Feb 23, 2008 | 08:08 AM
skn5002's Avatar
skn5002
If you want to lower your car without having to get a camber kit, go with hotchkis or teins.... although the drop will not be as low as you want
Old Feb 23, 2008 | 03:48 PM
Welcome. Check the suspension forum. Plenty of suggestions.
Old Feb 23, 2008 | 04:06 PM
Escobar's Avatar
Escobar
+1^, wrong section. IMO, if your gonna go that low save up and do it right with coilovers. If you use springs the ride is gonna be shitty and you will have to buy camber kits. good luck.
Old Feb 24, 2008 | 10:30 AM
rkd350z's Avatar
rkd350z
something like this?
Old Feb 24, 2008 | 06:28 PM
just_another_z
how low is that thing, whats it take to get mine that low?
Old Feb 24, 2008 | 07:04 PM
ginobetterfly's Avatar
ginobetterfly
yeah.. if you want a 2 inch drop , DO NOT go with Hotchkis springs...
Old Feb 25, 2008 | 04:38 AM
just_another_z
ok quick question, if I go coil overs do I need a camber kit or any other stuff? Also whats a good coil over set up to buy?
Old Feb 25, 2008 | 04:48 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
for street driving dont go less then mono flex's.
and to be safe on your suspension and for a better ride and better wear on your tires you WILL want to get a camber kit
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
