Question about life of shocks
Old Jan 28, 2008 | 02:04 AM
bhk1004's Avatar
bhk1004
Default Question about life of shocks
I have my oem shocks sitting in the garage for about 2 years now... they have around 20k miles on them. now the Question is... My gf's Z's shocks are dead, after 2 years are my shocks still going to be good or okay to swap into her car or no?
Old Jan 29, 2008 | 11:50 AM
bhk1004's Avatar
bhk1004
Anyone have any help on this?
Old Jan 29, 2008 | 12:35 PM
350ZTheStandard's Avatar
350ZTheStandard
Depends on how hard you ran em before you pulled em from your car. If you drove like a maniac every second you were in our car, they will probably be a bit closer to the end of their effective lifetime. You should be fine
Old Jan 29, 2008 | 12:41 PM
Fluid1's Avatar
Fluid1
How many miles on each set of shocks, and how hard were those miles? Get the shock tested?
Old Jan 29, 2008 | 01:09 PM
cheshirecat79's Avatar
cheshirecat79
Did you have aggressive lowering springs in conjunction with these stock shocks? If so, for how many miles?
Old Jan 29, 2008 | 06:38 PM
bhk1004's Avatar
bhk1004
it was a completely stock setup for normal daily driving for around 19k miles.
Old Jan 30, 2008 | 09:32 AM
Gsedan35's Avatar
Gsedan35
Not all oem Z shocks are the same. If your car is a 2003 car as your signup date here suggests, I would not remotely consider installing them. IMO, purchase Tokico HP oem replacements for about $250 and call it a day.
2004.5 shocks from the revised suspension are a totally different story, just to say it, those under the circumstances I would install on your girlfriends Z, just not 03/04 oem units.
Old Jan 30, 2008 | 01:27 PM
bbs350z's Avatar
bbs350z
whats so bad about the 03's??
Old Jan 31, 2008 | 05:56 AM
gothchick's Avatar
gothchick
03 = Tire feathering.
Old Jan 31, 2008 | 06:20 AM
bbs350z's Avatar
bbs350z
wouldnt that be because of excessive toe in, and more negative camber?
Old Jan 31, 2008 | 07:58 AM
Gsedan35's Avatar
Gsedan35
Bounce and freeway porposing.
Too much stiffness (compression dampning) and not enough rebound control. Nissan knew thier was a issue, the revised suspension introduced midway into 2004 production (which is why we call cars that have this suspension 2004.5 model year cars) addressed owner complaints about ride and drive quality. 2004.5 oem shocks aren't as stiff (less compression dampning) and have greater rebound control.
Old Jan 31, 2008 | 08:00 AM
Gsedan35's Avatar
Gsedan35
The 2004.5 suspension revision did not stop tire feathering issues.
Old Feb 1, 2008 | 05:28 AM
Q45tech's Avatar
Q45tech
Tire feathering is more about using directional tires with large blocks and failure to flip on wheels and rotate, than alignment per se.
Every brand of car with directional tires has some amount of heel toe feathering if they are not rotated to reverse scrub the level difference away.
High castor with camber gain adds to the problem...........try Michelin PS2 tires and rotate frequently.
Old Feb 1, 2008 | 05:56 AM
Gsedan35's Avatar
Gsedan35
I was hoping you'd chime in with what you know.
Old Feb 25, 2008 | 06:25 PM
350zGuy04's Avatar
350zGuy04
Hey guys whats the shock life after installing after market springs anybody?
issyz
Jul 2, 2017 03:04 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
