trying to install camber arms, must remove sway bar?
Old Feb 23, 2008 | 10:55 AM
ares's Avatar
ares
Veteran
Default trying to install camber arms, must remove sway bar?
I think its a sway bar, its not aftermarket, but I guess there is one stock. it seems to be in the way of removing the bolt on the inner side of the car. but Im being lazy, and want to be sure that needs to be removed before I disassemble more than I need to.
Old Feb 23, 2008 | 10:56 AM
redlude97's Avatar
redlude97
you can just remove the brackets and swing the bar out of the way
Old Feb 23, 2008 | 10:59 AM
ares's Avatar
ares
Veteran
hmmm ok, so that bracket right by where the bolt is, and I presume one on the other side, Ill try that.
Old Feb 23, 2008 | 11:11 AM
ev0k1ll3r's Avatar
ev0k1ll3r
yeah just take off the frame mount brackets and let the bar hang from the endlinks.
Old Feb 23, 2008 | 01:15 PM
ares's Avatar
ares
Veteran
well that did the trick, thanks guys, cambers looking much better, I need to get an alignment now.
