new brake pads
Well i just got a set of rotora front and rear brake pads (their H2 series) and plan on installing them this sat, my question for you guys is after I install them can i drive normally or do I have to break them in some how?
Thanks
Thanks
You should turn your rotors and make sure they're in spec.
Clean the rotor surface with brake cleaner and a towel.
Install new pads.
You can bleed the brakes if you want, but it's not necessary.
Replace wheels, lower car, start up car, pump brakes.
Begin the embedding procedure.
Install new pads.
