Help Tanabe Nf210!!!!
Old Mar 17, 2008 | 06:29 PM
pnoyryder's Avatar
pnoyryder
Default Help Tanabe Nf210!!!!
I got problem with my tires not being straight. the upper part is inside the fender and the bottom is sticking out. I instaled tanabe nf210 and i think it lowered 1.2 maybe a lil bit more. when i went to the shop they said that the rear can be adjusted but not the front because it didn't have camber kit. So im thinking about getting this camber that i saw at ebay. what do u guys think of it?? and there's another one and the brand name is ichiba its alil bit expensive but is that better?? and is that the whole kit? do i need anything else??? PLEASE HELP ME...... thank u which one should I get???? Do i also need the rear to be replace?
http://cgi.ebay.com/ebaymotors/PRO-1...3756.m20.l1116
http://cgi.ebay.com/ebaymotors/Ichib...3756.m20.l1116
Old Mar 17, 2008 | 06:39 PM
THE_SCHROED's Avatar
THE_SCHROED
If you just installed the springs you also need the camber kit. I just put the rear camber kit on. The shop said front was pretty close to stock so I wasn't too worried.
Old Mar 17, 2008 | 06:40 PM
BornSlippyZ's Avatar
BornSlippyZ
I think that is normal for the rear and front and I have the GF tanabe springs w/o a camber kit..tire wear is minimal...I would invest in some Tokico shocks before I get a camber kit...just my 2 cents. Be careful of e-bay specials..
Old Mar 17, 2008 | 07:09 PM
pnoyryder's Avatar
pnoyryder
so u guys think that if i get my car allign they would be able to straighten my wheels? because im scared that my tires my get worn out quick.
Old Mar 18, 2008 | 01:01 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
get a rear camber kit such as SPC, install, and get an alignment
Old Mar 18, 2008 | 02:00 PM
pnoyryder's Avatar
pnoyryder
why rear??? people at the shop said that the rear can be adjusted only the front that can't. u guys think w/o camber kits only alignment my tires will go for a year or maybe more than a year?
Old Mar 18, 2008 | 02:03 PM
saberphx's Avatar
saberphx
Doesnt nf210's lower the car like 2" all around? deff need camber arms for that much lowering.
Old Mar 18, 2008 | 02:13 PM
pony_killer
Arada ninda apa
oh my fault..i read it wrong. get the front, install, and get an alignment. the NF210's lower the car 1.25 all the way around if I'm not mistaken...but after they settle they should sit a little lower. i had the NF210's on my civic back before I got the Z and it said they lower the car 1.5 inches all the way around and that camber kit is not required..a few months later car was sitting very low (looked clean but not slammed) and I had to invest in a SPC camber kit for the front and back.
Old Mar 18, 2008 | 02:23 PM
MR_X's Avatar
MR_X
You are going to need both (front and rear) if you want to get it to a 0 degree alignment. Do go cheap, specially in suspension items, you don't need to put yours or others lifes on a cheap part.
Old Mar 18, 2008 | 03:00 PM
THE_SCHROED
What makes you say?
Old Mar 18, 2008 | 03:58 PM
350ZPK's Avatar
350ZPK
I just ordered the GF210, and should be fine without the camber kits.
Just depends..some get it back into spec and some dont....
Old Mar 18, 2008 | 04:04 PM
THE_SCHROED
I don't know if it needs it for the front or not. I had to replace my fronts cause of inside wear, but I drove without an alignment for a few months so I think that was why. I'll just have to see with this set if it starts to wear uneven. I definately had to get a kit for the rear though.
Old Mar 18, 2008 | 07:34 PM
playa6tnine's Avatar
playa6tnine
camber kit for front and rears will be needed.
shoot, i'm on stock suspension (until next week) and i already have rear camber issues. its probably due to the weight of my sound system.
Old Mar 19, 2008 | 05:13 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. you don't want the tires to be straight - follow the factory recommended settings for camber and toe (any alignment shop will have these figures). If you end up slightly more negative than stock, don't worry, it will be fine. Toe kills tires more than camber, and toe is adjustable up front via the tie rod ends.
2. rear is adjustable, but not by a significant amount. If you have wheels and tires wider than stock with a lower offset than stock and you're now lowered, you might find even stock pieces won't get you back into spec. My guess is you will definitely need a rear camber kit. We recommend the SPC:
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1314
Old Mar 19, 2008 | 05:19 AM
playa6tnine
Don't you want them straight though? for minimum amount of tire wear, arent you supposed to align it to 0 degrees all around? i know this messes with the handling slightly but i though 0 all around was ideal...
i could be wrong
Old Mar 19, 2008 | 05:28 AM
Z1 Performance
Former Sponsor
Unless you are a long distance truck driver, I would not recommend setting the camber to 0 all around. What you'll end up with is a car that is extremely numb, and not nearly as fun to drive. Straight up and down is not going to give you good handling, and is not going to gve you any meaningful increase in tire wear. Toe kills tires, not camber. Follow the factory specs.
Old Mar 19, 2008 | 08:40 AM
350ZPK's Avatar
350ZPK
+1 for toe kills
Old Mar 19, 2008 | 08:54 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i got SPC rear camber/toe together. Got more discount from vendor.
Installed them one time. got more discount
align one time . saved my time.
End up saved money/time + less Stress.
Old Mar 20, 2008 | 04:43 AM
playa6tnine
cool man, makes perfect sense
James1990
Dec 16, 2015 08:57 PM
CESAROTORRES
Texas
Jan 28, 2005 08:21 PM
bimmer10
Nov 16, 2004 02:54 AM
CESAROTORRES
Southern California
Oct 24, 2004 12:38 PM
bimmer10
Jul 12, 2004 08:12 AM
