My tunning shop said i didn't need the rear toe adjustment bolt from SPC Kit
Old Mar 19, 2008 | 02:43 AM
Colin_S's Avatar
Colin_S
Default My tuning shop said i didn't need the rear toe adjustment bolt from SPC Kit
I've dropped my Z to the lowest setting on Tein Flex and also cut the rubber top mount so it is pretty dam low but my tuner who fitted my SPC camber kit on the rear said that I didn't need the toe adjustment bolt fitted as he could get the toe aligned without it.
Is he talking BS?
Thanks
Colin
Old Mar 19, 2008 | 03:15 AM
calin's Avatar
calin
hmmm thats weird cause i have the same camber kit and the shop that put mine on did use the toe bolts. not really sure there. i think you DO need them to get back into spec
Old Mar 19, 2008 | 06:58 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
that is a little hard to believe that he could get it in spec after it's been dropped that low. what you could do is ask for the before and after alignment sheets and see. then if he is talking BS, install the bolts and have him do it again. he shouldn't be charging you for the second time.
Old Mar 19, 2008 | 07:53 AM
redlude97's Avatar
redlude97
+1, also what is his definition of in specs? Nominal value or just a hair inside the very wide OEM specs
Old Mar 19, 2008 | 08:20 AM
mdracer76's Avatar
mdracer76
Did your shop perform an alignment after the install work?
If not.. there is no way they know you do, or do not need the bolts...
my guess is you will need them.
Old Mar 19, 2008 | 09:04 AM
Colin_S's Avatar
Colin_S
They installed the Tein kit and the front and rear camber kit and did all the geometry alignment, and did not use the bolts. When i pickup the car they gave me them back and said i did not need them.
The bolts are for toe yes? Surely there is not a wide range of OEM specs for toe is there? Camber yes but not toe?
Old Mar 19, 2008 | 09:15 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Rear camber/toe adjustment is limited stock. Post the alignment sheet before/after.
Old Mar 19, 2008 | 12:42 PM
350ZPK's Avatar
350ZPK
Old Mar 19, 2008 | 12:50 PM
Colin_S's Avatar
Colin_S
I think it's BS, just want conformation from you guys.
Don't have a alignment sheet
Old Mar 19, 2008 | 01:47 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i guess he doesn't like hard job
Old Mar 19, 2008 | 02:17 PM
redlude97's Avatar
redlude97
What kind of hack shop doesn't supply an alignment sheet. How do you even know they did one at all?
Old Mar 19, 2008 | 07:31 PM
terrasmak's Avatar
I'm dropped 20mm in the rear and have no camber kit at all, and yes my car is within spec. It is possible.
Old Mar 19, 2008 | 07:35 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
keep in mind that 20mm is only about 3/4".
Old Mar 19, 2008 | 07:46 PM
Motormouth's Avatar
Motormouth
and jesus ****ing christ people, it is TUNING not tunning. I am so sick of seeing people saying that.
Originally Posted by google
Did you mean: define: tuning
No definitions of tunning were found in English
Old Mar 19, 2008 | 10:12 PM
chromesilver6's Avatar
chromesilver6
If he did get the toe "in spec" then you are running alot of negative camber. The stock toe bolts are kinda limited. I would take it to another shop or ask for a print out for sure.
Old Mar 19, 2008 | 11:12 PM
marques1's Avatar
marques1
******** you need the toe bolts i promise unless you want to go through your tires really quick. dont learn the hard way like me.
Old Mar 20, 2008 | 01:21 AM
Colin_S's Avatar
Colin_S
I'm in the Uk so i don't know if it is different but i've never had an alignment sheet before after using a number of shops. I've never had to have camber adjusted but have had toe adjusted regularly on other cars.
It is going back in to have the geometry redone after the springs are all settled in and i will tell him he needs to use the toe bolts.
Old Mar 20, 2008 | 05:04 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Colin, if you've driven the car more than 100 miles with the coilovers in, everything is settled...get it corrected asap so you don't kill your expensive tires! What I would suggest is speaking to the shop that did the alignment, and have them put the car back on their alignment rack for inspection. Ask them to show you the values for each of the 4 wheels and compare that to what the nominal specs should be (this info will be in the alignment machines computer). Remember, as you change camber, you change toe automatically, and vice versa. Make the changes as needed, and request the printout after its done so you have it to refer to for future alignments.
Old Mar 21, 2008 | 07:22 PM
5150DS's Avatar
5150DS
I thought it was twoning.
Old Mar 21, 2008 | 07:31 PM
playa6tnine's Avatar
playa6tnine
tow affects the tires more than camber does... i would get use the towbolts regardless of what the shop says
