Alignment after Tanabe GF 210 installed
Old Mar 25, 2008 | 03:27 PM
Spoiled Z's Avatar
Spoiled Z
dutchboy350Z - Tire Kingdom did not make those specs up. They got it from Nissan and those specs are specs for our cars.
Old Mar 25, 2008 | 07:59 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Front Left: Camber -1.7 -1.5
Toe 0.02 0.02
Rear Left: Camber -1.5 -1.7
Toe 0.04 0.05
this is what i got with Spc rear camber/toe installed.
it's been a while but i remember this align guy told me that he can adjus more in rear camber if i want to.
Old Mar 26, 2008 | 05:21 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'd love to know how they changed your front camber with out you having a means of front camber adjustment....
Old Mar 26, 2008 | 07:28 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Originally Posted by Spoiled Z
dutchboy350Z - So what do you think is wrong with my specs. The rear toe?
This is straight from the Nissan 350Z TSB.
For a 18" wheel the Rear toe should be a "minimum" of 0.043, "maximum" of 0.106. The ideal setting is 0.075. My shop set my rear toe to 0.08.
Old Mar 26, 2008 | 11:21 AM
Spoiled Z's Avatar
Spoiled Z
I dont think they did anything to the front camber. The numbers are still the same.
Old Mar 26, 2008 | 11:24 AM
Nexx's Avatar
Nexx
so you can only slightly adjust the front toe right?
Old Mar 26, 2008 | 11:35 AM
Z1 Performance
Former Sponsor
per your post
Camber
Before(L) -2.1 (R) -1.2 After (L) -1.0 (R) -1.2
Z1 Performance
Former Sponsor
it's not a slight amount..toe has a wide span of adjustment, its just done via the tie rod ends, so lots of room to play
Old Mar 26, 2008 | 12:14 PM
Spoiled Z's Avatar
Spoiled Z
per your post
Camber
Their machine is off as far as numbers on the left camber. He showed me print outs of peoples cars alignment report and its showing camber is off by 1 degree on the left. That is why I'm going to a different tire kingdom when I get the next alignment to verify the facts.
Old Mar 26, 2008 | 12:38 PM
350ZPK's Avatar
350ZPK
Mine are getting installed in about 25 minutes
I ordered some rear camber arms........just in case.
Old Apr 1, 2008 | 07:29 PM
greyvee05's Avatar
greyvee05
GF spring owners.. do you have tire problems or need camber kit especially on 19 inch rims?
Old Apr 2, 2008 | 04:03 AM
Z1 Performance
Former Sponsor
this same question has been asked and answered probably 30 times in the last 2 weeks
The short answer is...it depends. Every car comes from the factory with different settings, and where the car starts out determines where it ends up as far as alignment. Some will be able to get back to factory specs after springs, even with a 1 inch or 1.2 drop, some cars will be completely out of spec even with a 1/2 inch drop. The best thing a camber/toe kit does is, at the very least, let you make the figures perfectly even from side to side, ensuring consistent handling during left and right turns, and ensuring good tire wear. When you lower the car, it's always advisable to at least purchase a rear camber/toe kit
Old Apr 2, 2008 | 06:53 AM
350ZPK's Avatar
350ZPK
i will be getting alignment without my camber kit installed..we'll see what happens!
Old Apr 5, 2008 | 06:03 AM
Spoiled Z's Avatar
Spoiled Z
How did your alignment go?
Old Apr 11, 2008 | 07:53 PM
350ZPK's Avatar
350ZPK
im getting it done on monday..
Old Apr 13, 2008 | 04:39 AM
Spoiled Z's Avatar
Spoiled Z
I ordered me an adjustable A arm and rear camber/toe kit. I'm not very happy with the numbers and since I put on my work wheels I can clearly see how the camber is all jacked up. Going to install it next week as soon as it gets here!
Old Apr 16, 2008 | 10:19 AM
Spoiled Z's Avatar
Spoiled Z
UPDATE
So after a month I decided to have my alignment done again. Here are the numbers.
Cambers
-1.8L and -2.0R (Front)
-2.1L and -2.1R (Rear)
Toes
0.05's on front and back
I have an Adjustable A arm and camber/toe kit but thinking about not installing them since I'm on the borderline. What do you guys think. I'm thinking about just getting the MD spacers + MREV2
Old Apr 16, 2008 | 10:39 AM
  #38
dutchboy350Z
Finally some go
UPDATE
Cambers
Toes
It's your call. Those specs are pretty decent.
Old Apr 16, 2008 | 10:43 AM
  #39
Spoiled Z's Avatar
Spoiled Z
sigh....sigh....
Old Apr 16, 2008 | 10:47 AM
  #40
Chef-J's Avatar
Chef-J
Booooosstt!!
i will still install them if you have in ur hands.
nobody know maybe one day you wanna get 19" crazy setup~
