Uneven ride height?
Old Apr 3, 2008 | 03:44 PM
350ZPK's Avatar
350ZPK
Default Uneven ride height?
I just got my GF210's installed, put probably 200 miles on her after the install. The rear right is higher then the left rear on even pavement. It is probably a finger and a half higher...
Ideas? Or is it still trying to settle?
Old Apr 3, 2008 | 03:50 PM
haeshik's Avatar
haeshik
pictures would help. i would reinstall and check over everything. ride height should be even regardless of springs settling in or not
Old Apr 3, 2008 | 07:05 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. make sure the pavement is 100% even....most times, even though it might look it, it's not and that can cause the car to sit a bit 'funny'
2. springs don't always lower every car an even amount front to back or even side to side - before measuring drops, etc, best bet is to drive the car around a bit. It's not actually the springs that settle most times but the rubber mounts. A few days of driving might be enough, or it may take up to a week sometimes..every car is different
Old Apr 3, 2008 | 09:30 PM
syndacit's Avatar
syndacit
Tire Pressure? Wear on tires?
Old Apr 4, 2008 | 07:33 AM
350ZPK's Avatar
350ZPK
tire pressure is fine. Tiresr have plenty of even meat left.
Old Apr 4, 2008 | 07:35 AM
350ZPK's Avatar
350ZPK
Pavement in even. I will have the shop that a look tonight. THanks
Old Apr 4, 2008 | 08:04 AM
App6MT's Avatar
App6MT
My G coupe was sitting about 3/4" lower on the drivers side. I bought coilovers to correct it.
Old Apr 4, 2008 | 11:04 AM
three_fitty's Avatar
three_fitty
how do you guys measure your coilovers?
i set my front preloads the same and adjusted the length of them to be the same as well. Same with the rears; but it seems some corners are higher/lower than the others. About a difference of 1/4".
Should i just measure each corner individually? Or does it really matter?
Hope i make sense.
Old Apr 4, 2008 | 11:42 AM
350ZPK's Avatar
350ZPK
How about you get ur own thread ; ) hint hint
Old Apr 4, 2008 | 11:55 AM
three_fitty
holy... ya i'll do that. and call it "uneven ride height"
Old Apr 4, 2008 | 04:36 PM
350ZPK's Avatar
350ZPK
well then im guessiing your a dumb ****
Old Apr 4, 2008 | 07:03 PM
haeshik's Avatar
haeshik
lol at you guys. but seriously start your own thread its annoying
416blueZ
Jun 11, 2024 10:56 AM
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
416blueZ
Sep 24, 2015 02:11 PM
