Most Rear Camber you can run Safely?
Old Apr 7, 2008 | 01:54 PM
DMK's Avatar
DMK
Default Most Rear Camber you can run Safely?
What's the most amount of rear camber you can run safely on the street?
If I did -3 in the rear, would that be too much? I might even need to push it more than that, not sure yet.
Thanks.
Old Apr 7, 2008 | 02:38 PM
redlude97's Avatar
redlude97
Old Apr 7, 2008 | 03:01 PM
DMK's Avatar
DMK
Originally Posted by redlude97
-10
I would still like to have some straight line traction.
Old Apr 7, 2008 | 05:36 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I run -2 on my car
Old Apr 7, 2008 | 05:57 PM
julian's Avatar
julian
depends on how much straightline driving you do.
but i think -3 in the rear will be too much even for track work.
haeshik's Avatar
haeshik
^^^ same here i run -2
Old Apr 10, 2008 | 09:54 AM
OffsetZ33's Avatar
OffsetZ33
I run around -3/-3.5
Old Apr 10, 2008 | 10:47 PM
terrasmak's Avatar
-2 rear here and -1.5 front.
Old Apr 18, 2008 | 05:43 PM
eddie lee's Avatar
eddie lee
well, you will get much better cornering with neg camber. But the downside are uneven tire wearing and your car might float a little bit, if you go really fast.
Anything less than -3 should be safe!
Old Apr 23, 2008 | 09:29 AM
3m wol8's Avatar
3m wol8
how's your tire wear?
Old Apr 23, 2008 | 09:46 AM
WhiskeyHotel's Avatar
WhiskeyHotel
Ok, ok. The engineer in me is screaming anything less than -3 would be a larger negative number, like -3.5. Negative numbers work backwards - less is more and more is less, um, you know. lol
Old Apr 23, 2008 | 11:43 AM
Zridder19's Avatar
Zridder19
I run -2. No problems
Old Apr 23, 2008 | 12:10 PM
JETPILOT's Avatar
JETPILOT
You have to keep in mind that the more negative camber you run the less effective the car will be in braking and accelerating. I use my car on the track and run -2.0 F and -1.6 R. That is a happy medium. Keep in mind the on the street the road is crowned and that puts even less of the tire in contact with the street which could lead to overheating and possibly failure on the portion of the tire in touch with the pavment.
JET
Old Apr 23, 2008 | 06:38 PM
eddie lee's Avatar
eddie lee
Beside the neg. on camber, the degree on toe can also affect the tire wear. Where in CA are you locate at? I know some really good alignment shop in Sacramento area, they can adjust the toe and camber by ur tire wearing! Also, by using the non-directional tire can also help the wear. At least u can keep rotate them and flip them! I use Nero P-zero, very good on wet, but not too good on try. Perfect for street use.
Old Apr 23, 2008 | 06:49 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I run -3.2 on the rear and -3.0 up front with the Nt01's 295/315 and is just incredible. I have ran that on the street for about 1300miles with no problem. I run -2, -2 all around with the street tires and have no major traction problems.
I recommend -2 all around with 19" wheels and simi big rubber. -3 on the track all day long, with some nice R compund tires.
Street
Track!
Old Apr 23, 2008 | 07:50 PM
JETPILOT's Avatar
JETPILOT
That's a shyt load of camber. I don't know how you get traction with -3 on the track.
Is that the same car? What are your wheel sizes/offsets? What shocks and srping rates are you running?
JET
Old Apr 24, 2008 | 12:12 PM
eagletanggreen
Got Track!!!!!
Yep same car I have a track bumper and side skirts I put on. I rather sacrifice a little traction for more corner grip. It not that bad at all.
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
